What Is A Washer And Tube Called - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By wooleybooger
Unread 02-09-2020, 06:25 PM   #1
Rewards Points: 82
What is a washer and tube called
I need to drill holes in sheet metal for some bolts. The bolts will go through the sheet metal horizontally. I am a little concerned about the threading causing shear. I have seen hardware where a tube is used around a bolt, something like the following but smaller and much less expensive.
What I need would be sheet-metal quality so quite economical but I just don't know what to call it so I don't know how to search for it.
Sam Hobbs is offline   Reply With Quote
Unread 02-09-2020, 06:45 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,588
Re: What is a washer and tube called
Cheap steel flanged bushing.
The Following User Says Thank You to joed For This Useful Post:
Sam Hobbs (02-09-2020)
Unread 02-09-2020, 07:24 PM   #3
Rewards Points: 9,442
Photo that you posted looks like a "drill bushing"
A straight smooth bushing for sheet metal ? Never heard of that. But pretty common are threaded inserts for sheet metal. Commonly pressed and crimped into sheet metal. Search "rivet nut". McMaster Carr or many other places. Suppose you could drill out a rivet nut if you really wanted a straight bore.
SPS-1 is online now   Reply With Quote
Unread 02-09-2020, 08:04 PM   #4
Rewards Points: 18,384
More info on what your really trying to archive would be helpful.
Without a backing plate anything you try to use to use will flex and cause vibration.
Unread 02-09-2020, 08:23 PM   #5
Rewards Points: 82
Thank you. I see many examples in flanged bushing - Google Search, such as:
OILITE BRONZE FLANGED BUSHINGS | Aircraft Spruce
Eco Bronze C87850 Flanged Bronze Bearing Bushing | Bolton Industrial
Now I need to determine if a local hardware store such as Home Depot or Lowes sells items such as that but at least I know what to look/ask for.
Unread 02-09-2020, 08:29 PM   #6
Super Moderator
joed's Avatar
You might have better luck at a store like napa or a farm supply store than a big box hardware store.
Unread 02-09-2020, 11:33 PM   #7
JUSTA MEMBER
Rewards Points: 1,638
Look up Barrel Bolts.
The sleeve insert is threaded and then a bolt screws into the end of it, holding it in place.
I buy them in HD, in the bolts / nuts aisle, they come in many sizes and lengths.
ED
de-nagorg is online now   Reply With Quote
Unread 02-10-2020, 07:35 AM   #8
wooleybooger's Avatar
Rewards Points: 1,052
Barrel bolt also interchangeably known as a Sex Bolt
Pop Rivet. Not for something to be disassembled and requires a special tool to install.
There's no such thing as free lunch, too much horsepower or spare change~anonymous
There is no such thing as free shipping either~Wooleybooger
wooleybooger is offline   Reply With Quote
Unread 02-10-2020, 07:49 AM   #9
JUSTA MEMBER
And those barrel bolts are not limited to the tapered head screw.
I have used many PAN HEAD screws, the threads are the same, and the Pan Head holds flat stock easily.
ED
Unread 02-10-2020, 08:10 AM   #10
Property Mgt/Maint
Rewards Points: 7,638
Possibly some inexpensive grommets might work. Pending the application.
https://www.homedepot.com/s/gromets?NCNI-5&gsitesearch
[political signature removed]
Yodaman is online now   Reply With Quote
Unread 02-10-2020, 03:14 PM   #11
ED
Yes, I've also seen them in photo albums to allow the album to be easily disassembled to add pages.
de-nagorg likes this.
Unread 02-10-2020, 04:13 PM   #12
Oso954's Avatar
Rewards Points: 928
In the photo albums or similar binding tasks, they are called Chicago screws.
They come in various lengths. You can also get various extension rod lengths.
Available at any good office supply.
While they do allow the disassembly/page insertion/replacement, they are also just a good way of binding a lot of paper together. If you are doing a lot of Thick reports, it helps to have a paper drill rather than hole punches.
Oso954 is online now   Reply With Quote
Unread 02-10-2020, 04:19 PM   #13
Paper Drill --- cool. Never heard of them before.
Unread 02-10-2020, 07:19 PM   #14
Got to agree though I've never heard the term Chicago screw. I've heard of paper drills but never seen one.
