What Size Should The Reinforcing Welded Corner Be? - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By Nealtw
Old 12-08-2017, 09:56 AM   #1
hohadcr's Avatar
Rewards Points: 448
what size should the reinforcing welded corner be?
Building a metal structure for a one storey double garage.
I will need to weld W6x12 I beam with W8x24 I beam in a 90 degree corner.
In the engineering drawing, it asks for welded steel corners to be put in place to reinforce this corner weld, but the size of the welded steel corners will be up to the welder to decide.
So, what size should be the welded steel corners?
Or are the welded corners just angle beams like this one?
https://www.homehardware.ca/en/rec/i...jrf/R-I2192599
or this?
https://www.homehardware.ca/en/rec/i...jrg/R-I2192585
Thanks a lot
hohadcr is offline   Reply With Quote
Old 12-08-2017, 10:26 AM   #2
JUSTA MEMBER
Rewards Points: 4,004
Re: what size should the reinforcing welded corner be?
I would use the solid ones, in the same thickness as the I beams are.
ED
de-nagorg is offline   Reply With Quote
Old 12-08-2017, 10:34 AM   #3
retired framer
Rewards Points: 20,276
or this?
Thanks a lot
I think you are looking for something a little more heavy duty.
Bondo likes this.
Old 12-08-2017, 02:20 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... As Neil points out, the steel you need don't come from a boxstore,....
Talk to the Supplier yer gettin' the I-beams from,...
Old 12-08-2017, 02:28 PM   #5
hohadcr's Avatar
Rewards Points: 448
The metal suppliers don't have anything "welded". I can ask them for angle steels.
So the angle steels that I want to order for the joint of W8x24 and W6x12 is something like 3"x3", 1/4" or 3/8" thickness?
Old 12-08-2017, 03:06 PM   #6
retired framer
I think more than likely they want you to design the joint. You are dealing with beams that would support tons and you won't find anything off the shelf at HH for that.
Old 12-08-2017, 04:47 PM   #7
Bondo's Avatar
There should be a detail drawin', in the engineer's drawin',....
Use a scale to find the size,....
glue corner beads and tape? begal Drywall & Plaster 16 04-09-2017 07:22 PM
Corner bead for a 5" corner issue? dfphoto Drywall & Plaster 7 07-27-2015 01:51 PM
Drywall Product Review Video - Corner Bead on a Roll Sir MixAlot Drywall & Plaster 7 07-19-2015 04:30 PM
Seeking Advice for Inside Corner Drywall Cracks/Wall Shifts Boar Drywall & Plaster 1 06-24-2011 12:13 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
