Trying To Identify A Steel Bracket - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By 3onthetree
  • 1 Post By ChuckF.
Old Today, 09:44 AM   #1
tom_poconos's Avatar
Rewards Points: 446
Question
Trying to identify a steel bracket
Hi! Sorry, this is not strictly a fabrication question but I thought folks in here might be able to help.
Can anyone identify this metal bracket - or something similar that I can buy in a bag of 20 or so? I had a few in my "bits bag". I don't know where they came from. But they're really perfect for hanging round metal ducts using screw hose clamps.
It's basically a small mending plate (2" x 0.5") with some bends in it. It is identical in structure to a steel bar holder, but much smaller.
Follow up question - if I were to try and turn mending plates into a brackets like this, what kind of machinery would I need?
Thanks for any advice!
Trying to identify a steel bracket-img_20200312_103047.jpg   Trying to identify a steel bracket-img_20200312_103116.jpg
On the one ton temple bell
a moon-moth, folded into sleep
tom_poconos is offline   Reply With Quote
Old Today, 09:57 AM   #2
retired framer
Rewards Points: 7,386
Re: Trying to identify a steel bracket
It is a top hat bracket or maybe a shallow top hat bracket.
Colbyt likes this.
Do not use flat bottom gables with scissor trusses.
Old Today, 10:04 AM   #3
Rewards Points: 7,651
Great call. I learned something new today.
A vice, vise grips and a hammer. It can be done but they will be crude.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old Today, 10:15 AM   #4
retired framer
https://www.amazon.ca/Pxyelec-Stainl...37083811&psc=1
Or just use a mending plate with a washer or nut under the ends.
tom_poconos likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
tom_poconos (Today)
Old Today, 01:48 PM   #5
Rewards Points: 446
Amazing, thank you!
Interestingly it seems really hard to get them in the US. They're common in the UK and elsewhere.
I thought about using a mending plate with washers as you mentioned, it would be a bit fiddly especially when installing in precarious, upside-down places but definitely workable, and also there'd be less slack under the plate.
Old Today, 02:06 PM   #6
retired framer
Originally Posted by tom_poconos View Post
Amazing, thank you!
It might just be a different name to look up to find them here.
Double sided tape the washer in place on them.
Old Today, 02:39 PM   #7
Hammered Thumb
Rewards Points: 1,140
I'm guessing to make those short tight bends from flat mending plates you would need a hydraulic press.
If you are using them for duct hangers and have to buy more hat shapes + worm gear clamps, might as well buy prefab ones, they have in plastic or galv. clamp style, can also go to B-vent style.
Edit: you can also search "strut bracket" besides "hat"
Nealtw likes this.
3onthetree is offline   Reply With Quote
Old Today, 02:52 PM   #8
Rewards Points: 446
Can you link me to the prefab duct clamps you speak of?
Old Today, 03:19 PM   #9
Hammered Thumb
Few different styles, searching HD is strange, there is not 1 section for them. You have to search something like HVAC/duct/accessories, or plumbing/gas fittings, they're all over the website. Here's one version of hanger I found quick
HD 5" vent pipe hanger
Grainger and Amzn is easier.
Also just perforated strap is cheap and works real well. If you are holding up a duct between joists you can just rest it on a telescoping support. Many options for whatever the situation.
Old Today, 04:02 PM   #10
Rewards Points: 446
I see. I have seen those. They're nice but hugely overpriced (Grainger wants $20 for a single 6" hanger, and I need 8" hangers). The pricing of the various hangers out there is extremely arbitrary, I'll never understand it. Thanks anyway, I might use the expensive prefab ones in exposed locations for aesthetic reasons.
Old Today, 09:05 PM   #11
Rewards Points: 1,924
Looks kind of like the brackets on the inside of a garage door, that the long locking bar slides through.
Nealtw likes this.
ChuckF. is online now   Reply With Quote
Old Today, 09:59 PM   #12
Rewards Points: 18
A fabrication or sheet metal shop should be able to crank them out pretty quick.
Sent from my SM-G960U using Tapatalk
spitz1234 is online now   Reply With Quote
