Tool Recommendation - Cutting SS Cable - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By Canarywood1
Old 05-04-2018, 02:36 PM   #1
Rewards Points: 539
I'm installing a cable railing system on my deck. This is my second installation with this same manufacturer over a period of a few years. The cable is 1/8" SS, multi strand. One MUST have a "clean cut" end on this stuff so some one way anchors will slide on and secure it to the end post. I screwed up and in pulling my first long run through the posts, a strand started to peel back from the factory end. Fortunately, I stopped the unravel in time, so there remains enough useful cable to complete the installation of that run. However, I need to create another round, intact, non-unraveling end on that piece, i.e., I need to cut it. Some nightmares from my first experience with this stuff float through my head.
So I'm looking for recommendations as to specific tools and techniques to get me where I need to be.
Curmudgeon10 is offline   Reply With Quote
Old 05-04-2018, 04:37 PM   #2
Rewards Points: 2,906
Re: Tool Recommendation - Cutting SS Cable
Many years ago in the Military we would rap electrical tape around the cable than use a Guillotine cutter than you applied force with a large hammer clean cut. Also had some kind of very hard wax like substance that when melted would form a coating on the cable end to hold the strands together. I think now a day you could use a Hot Glue gun ? Also you can purchase a hand held cable cutter for around $ 50.00.
ClarenceBauer is offline   Reply With Quote
Old 05-04-2018, 05:36 PM   #3
Rewards Points: 1,042
Wrap the 2 inches above and below the cut with electrical tape, and cut in the middle with an angle grinder with a cutting wheel, neat clean and fast.
Yodaman likes this.
Canarywood1 is offline   Reply With Quote
Old 05-04-2018, 06:30 PM   #4
kwikfishron's Avatar
Rewards Points: 332
This is what you need. https://www.diyhomecenter.com/azek-c...YaAiySEALw_wcB You can the 3/16" or for whatever size of calbe you're using.
Whoever you bought the cable rail parts from should sell the cutter and crimping tool too.
You need the right tools otherwise you'll be fighting it all the way trying to get all of those nifty little accessories to work.
kwikfishron is offline   Reply With Quote
Old 05-05-2018, 10:24 AM   #5
Rewards Points: 539
Thanks! I'm going with this idea. Perhaps I'll gild the lily a bit by dropping some CA adhesive on the strands in between the tape.
Wires all mixed up Bucksco3433 Electrical 21 03-08-2017 08:18 PM
Drywall power cutting tool.... busarider29 Drywall & Plaster 18 12-28-2016 07:08 AM
Armored cable shell as conduit? sixspeed Electrical 13 10-18-2012 03:45 PM
Tool stand recommendation Ranger1227 Tools 5 05-16-2011 08:37 PM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
