Thick Aluminum To Aluminum! - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree3Likes
  • 2 Post By stick\shift
  • 1 Post By Bondo
Old 05-15-2017, 07:59 AM   #1
Rewards Points: 336
Thick Aluminum to Aluminum!
Wasn't 100% sure where to stick this thread but I am trying to attach a piece of aluminum to aluminum. I am sure the proper way to this is with a weld but that is not an option. The one piece of aluminum I am attaching too is deep to get a bolt & nut threw. So my question is there a self locking bolt or screw that I could use to attach these two with a good amount of strength? I feel like a self tapping screw wouldn't be enough. Any other idea's or suggestions would be great appreciated. Thanks much in advance for your time and help!
cbaur88 is offline   Reply With Quote
Old 05-15-2017, 03:10 PM   #2
Rewards Points: 202
Re: Thick Aluminum to Aluminum!
Pop rivet? Speed nut?
Old 05-15-2017, 03:17 PM   #3
Rewards Points: 4,170
More about the size and shape of the pieces and application would help.
Bondo and joecaption like this.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
Bondo (05-15-2017)
Old 05-15-2017, 05:52 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,... Atleast put some dimensions of the materials ya wanta join,...
Just how thick is thick, 'n how thin is thin,..?.. in inches,..??
Pictures would be even Better,...
There are larger self-tappin' screws, or there's drills, 'n taps for machine threaded fasteners,....
As well as rivets, 'n such,...
or good ole balin' wire, 'n duct tape,....
kwikfishron likes this.
Old 05-15-2017, 07:05 PM   #5
Civil Engineer
Rewards Points: 5,246
I have no idea what you mean by a "good amount of strength". Are you supporting an elephant on the end of an aluminum cantilever? I don't mean to be difficult, but you include no information about the size of the pieces, the load, the intended use, the limitations of installation. You may get a reasonable answer if you thoroughly, accurately and carefully describe what you are trying to accomplish, with dimensions, a drawing perhaps, or maybe some photos.
Aluminum Fascia (buying rolled aluminum vs panels) Sandywjo Building & Construction 4 02-20-2016 08:01 AM
How to disassemble aluminum clad wood window sash? JohnBinSC General DIY Discussions 6 01-17-2011 05:59 AM
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
