Strengthening TREX With REBAR - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 05-16-2019, 04:07 PM   #1
Rewards Points: 591
Strengthening TREX with REBAR
Perhaps not the correct forum, but I'll take a shot.
I have a bench, about five feet in width, that consists of two curvy concrete end pieces held together by wood planks. Think bulky looking park bench. It has seen better days, and also needs to be relocated. Perfect excuse for rehab.
The current boards are all checked with some dry rot, so they need to be canned. I live on the water, and the environment is not friendly to wood, pressure treated or not. I'd like to replace the boards with TREX. The parts that butts would sit on consist of three approx 5' x 5" x 3/4."
Trex is of course not structural, so I'm thinking: what if I rabbeted a slot (or two) in each trex board on the underside and embedded some rebar, securing with construction adhesive.
Would that provide sufficient stiffness to support a couple of adults?
Curmudgeon10 is offline   Reply With Quote
Old 05-16-2019, 04:42 PM   #2
Rewards Points: 4,366
Re: Strengthening TREX with REBAR
I see rebar rusting faster than PT wood rotting.
stick\shift is offline   Reply With Quote
Old 05-16-2019, 05:36 PM   #3
retired framer
Rewards Points: 4,294
Epoxy coated rebar would work.
https://www.harrissupplysolutions.co...ted-rebar.html
Do not use flat bottom gables with scissor trusses.
Old 05-16-2019, 07:02 PM   #4
kwikfishron's Avatar
Rewards Points: 140
Maybe I'm missing something here but what I'm visualizing is two concrete bench ends with 5' deck boards spanning between them to create a bench.
If that's the case there's nothing you can do with rebar to make trex span that.
You'd need some kind of a rigid frame to support the trex every 16".
kwikfishron is online now   Reply With Quote
Old 05-16-2019, 07:51 PM   #5
Property Mgt/Maint
Rewards Points: 7,374
I can't see rebar helping much. How about alum channel bar fastened to the under side of the seat boards.
https://www.metalsdepot.com/aluminum...m-channel-6061
[political signature removed]
Yodaman is offline   Reply With Quote
Old 05-16-2019, 07:59 PM   #6
Rewards Points: 8,952
I'm with Ron on this one. If you plan on sitting on it, a couple of pieces of rebar are not going to do it.
Maybe look at Ipe (eepay). It will turn grey in the sun, but last a heck of a long time.
SPS-1 is offline   Reply With Quote
Old 05-16-2019, 08:13 PM   #7
Rewards Points: 591
Originally Posted by Nealtw View Post
Thanks! I am going to create one piece with two channels, with two lengths of this stuff, and see what the deflection is.
Old 05-16-2019, 08:14 PM   #8
Rewards Points: 7,646
Not a pro but any metal to provide support should be something like spring steel, think leaf springs. But even then the trex becomes just decoration.
Any way to fabricate a metal frame that arches up, over, and down? Something decorative like a fence maker could put together.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 05-16-2019, 08:28 PM   #9
Rewards Points: 591
Bud
Fabricators are hard to find for small one offs where I live. And what I have to work with (Concrete end pieces) is pretty mundane stuff, not really worth a bunch of time, effort and $. But I hear what you are saying about the materials. Perhaps I should visit the yard and see what they have. I'm definitely going to mock something up.
Old 05-16-2019, 08:48 PM   #10
Here's a fence I drive by occasionally:
https://www.google.com/search?q=step...iw=952&bih=454
Bud
Setting up rebar in poured concrete foundation wall aroostook Concrete, Stone & Masonry 6 11-03-2015 12:25 PM
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 12:26 PM
Trex decking LL1 General DIY Discussions 56 09-30-2011 10:55 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-04-2008 12:37 AM
