Steel Fireplace Facade For Metal Newbie - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By chandler48
Old 03-28-2018, 06:57 PM   #1
Rewards Points: 790
Steel fireplace facade for metal newbie
I have a fireplace that I hired a friend to cover with thin gauge raw steel. He has left the planet and is no longer contactable. Iím sure heís just overwhelmed with other work.
Looks like Iíll have to do this job myself. Our plan was to make it look like the picture below, but steel going all the way up.
What are some industrial looking options to cover up the fireplace? Iíd prefer to put some type of thin gauge steel up there.
Its 10í tall and 47Ē wide. The column on the right of the fireplace are for a vent. Iíd like to continue the same look on the vent.
jaketrades is offline   Reply With Quote
Old 03-28-2018, 07:21 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,240
Re: Steel fireplace facade for metal newbie
Not sure of your wall covering, but the fireplace, on the left side will need a metal stud and cbu in that 2" space, since sheetrock and wood studs are combustible products
jaketrades likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 03-28-2018, 07:28 PM   #3
Rewards Points: 790
Yup Iíll cover that with metal studs and cb.
Old 03-28-2018, 09:36 PM   #4
Rewards Points: 790
Food some sheetmetal fireplaces on Houzz.
Old 03-29-2018, 09:35 AM   #5
Rewards Points: 790
Thinking thin gauge raw steel plates. If I can get some large sheets, I can template the fireplace, scribe and cut with an angle grinder.
How do I deal with the sharp edges?
Old 04-06-2018, 10:14 PM   #6
Rewards Points: 790
Anyone know what type of metal this is? I saw it on a home in brooklyn. Thinking about putting this on my fireplace.
Remodelling den and fireplace doors coyote97 Building & Construction 0 11-22-2013 12:01 AM
Trying to troubleshoot a gas fireplace, need help glenh Appliances 3 11-03-2013 06:48 AM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 01:50 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
