Steel "C" Channel Strength - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By Bondo
Old 12-06-2017, 02:40 PM   #1
Rewards Points: 156
Steel "C" channel strength
I hope someone can answer this or direct me to an answer. What is the vertical strength of a steel "C" channel with outside dimensions of 3" x 1" x 3/16" x 36". At 18", I will be putting a 5/8" hole thru the center of the channel and I am concerned how much it will be weakened. I've probably just asked a simple question that requires a complicated answer, but any help will be appreciated.
captfl2x is offline   Reply With Quote
Old 12-06-2017, 04:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Steel "C" channel strength
Ayuh,.... What are ya wantin' to support with this 3' chunk of 3"x 3/16" channel iron, 'n how will it be attached to whatever this is,..??
Is it mill run hot rolled channel iron, or a flat stock, bent into a C channel,..??
This is hot rolled channel iron,....
Nealtw likes this.
Bondo is online now   Reply With Quote
Old 12-07-2017, 05:58 PM   #3
Rewards Points: 156
The channel is hot rolled and it is the span between two supporting members on a trailer.
Old 12-08-2017, 09:48 AM   #4
Bondo's Avatar
Ayuh,.... How long is the span, 'n how heavy will it be loaded,..??
Old 12-08-2017, 11:20 AM   #5
Rewards Points: 156
The C channels are the structural members on each side of the trailer and are in a vertical position. The length of the C channel where the hole will be is 36" without other support/reinforcement. The hole will be centered ion this 36" length. I will assume that the trailer will carry it's max load capacity of 3,000 lbs. The trailer load area is 5' W x 10' L. Of the 3,000 lbs, 300 # will be on the hitch. Assume the remainder of the load will be spread evenly throughout the load area. If that is the case, that is 54#s /sq. ft. or .375 # / sq inch.
The 36" length of unsupported C channel rail across the trailer would have 810 # on it (3'x5'x54#) or 405# per side C channel. Since the C channel has a leg of 1"W x 36" L, the weight would be distributed evenly at 11.25# per linear inch. There's probably is a flaw somewhere in my thought process or calculations, but maybe this will help.
Maybe a 5/8' hole in the center of the c channel would be negligible strength reduction but I can also only calculate a static load.
Old 12-08-2017, 02:14 PM   #6
Bondo's Avatar
Ayuh,.... You could step up to 3"x 1" x 1/4",. 'n go for it,....
it's pretty stiff stuff,....
I wouldn't sweat a 5/8" hole,.... incidental,...
Old 12-08-2017, 02:42 PM   #7
Rewards Points: 156
Thanks. The trailer is already built so I can't change to a 1/4". I just need to drill the two holes (one each side).
Old 12-08-2017, 04:48 PM   #8
Bondo's Avatar
Knowin' what yer tryin' to do would help,...
Old 12-08-2017, 06:44 PM   #9
Rewards Points: 156
Since I'm not a "spring chicken" anymore, I need help raising and lowering the drive-on tailgate. I believe that a lift will be needed only on one side but the other side should have a latch device. This trailer is a flat bed with no upper side rails to use.
Old 12-09-2017, 07:54 AM   #10
Bondo's Avatar
Ok,... but that doesn't explain how ya wanta use the channel iron,....
I suggest ya rig up something like This,....
Old 12-09-2017, 08:26 AM   #11
Rewards Points: 156
I've looked at that lifter assist before and if I had body rails I definitely would use it. There are several variations of that. Who ever was first didn't tie down the patent firm enough. Without body rails, I would use the holes thru the C channel as anchor points for my lifter. Early stages of planning. My first thought was to determine if the holes thru the C channels would be an issue. Appreciated your help.
Old 12-09-2017, 09:12 AM   #12
Bondo's Avatar
Nope,... Not enough to matter one bit,....
Old 12-25-2017, 11:46 AM   #13
Licensed Engineer
Rewards Points: 467
Will the hole be in the center of the 3-inch leg or the 1-inch leg? If the 3-inch leg then Bondo is absolutely correct. Placing a hole dead-center will put it on the neutral axis of the channel as you have installed it, and the neutral axis carries zero stress/strain.
MI-Roger is offline   Reply With Quote
Old 12-25-2017, 10:07 PM   #14
Rewards Points: 156
The hole will be in the center of the 3" leg. Thanks for the info.
Stainless Steel Appliance got grout cleaner on it! ckbenson02 General DIY Discussions 11 01-21-2015 12:51 PM
What's a good product to repair chip in steel tub to prevent rust? amodoko Plumbing 4 12-26-2011 08:37 PM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
