Spherical Bearing Question - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree5Likes
Old 10-28-2016, 10:42 PM   #1
Electrical Contractor
Rewards Points: 312
I have a question for someone who might be a millworker, or industrial mechanic.
I have a used NTN 24024B spherical roller bearing, and requiring a new one. It has an 4 11/16" bore and 7" outer diameter. It weights about 11.5 lbs.
This is a BIG bearing.....It's out of a Pettibone pipe carrier.
Anyone have a ballpark idea of what these cost new?
Power- is offline   Reply With Quote
Old 10-28-2016, 10:47 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,274
Re: Spherical Bearing Question
Power... No idea... But that is a beautifull piece of machinery...
What's it go to...
Windows on Wash likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 10-28-2016, 11:02 PM   #3
Rewards Points: 312
It comes from a Pettibone Pipe Handler.
I suspect it's one of the wheel bearings....I also suspect the bearing is worth a few grand
Old 10-28-2016, 11:26 PM   #4
Ouch....!!!!
Can't say I've been shopping for one lately...
Good luck...
Old 10-29-2016, 08:47 AM   #5
Rewards Points: 17,914
Not sure how it works up there, but in the US any city has places that sell power transmission products far cheaper then buying from the equipment dealer.
There often listed under "Bearings" in the yellow pages.
SPS-1 and Power- like this.
Old 10-29-2016, 09:12 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... Only if ya got a pettibone lift that needs that bearin',....
'n bein' a heavy equipment Mechanic, I've never seen a bearin' for that kinda money, even from a Dealer,....
joecaption and Power- like this.
Old 10-29-2016, 08:16 PM   #7
Rewards Points: 1,760
There may be some ID numbers etched onto that bearing somewhere. Go to a bearing dealer, not the vehicle manufacturer for better prices.
ChuckF. is offline   Reply With Quote
Old 10-31-2016, 09:35 AM   #8
Rewards Points: 312
I know this is not your "off-the-shelf" bearing.....
The numbers etched on it are the ones I mentioned in the original post. No other numbers (other than "JAPAN") are on the bearing.
Like joecaption suggested, I will go down to TSL, Transmission Supply Limited. They seem this kind of stuff.
Thanks All !!!
Old 10-31-2016, 09:53 AM   #9
Rewards Points: 7,608
I would have thought a bearing that size is normally a couple/few hundred dollars. Having said that, I don't think you have a particularly common part number, could be higher price.
SPS-1 is online now   Reply With Quote
Old 10-31-2016, 11:04 AM   #10
Super Moderator
joed's Avatar
Rewards Points: 23,810
This site has a ca version instead of the B version for between $55-$60. I don't know what the difference is.
Page 135
http://www.hellerbearings.com/images...list-price.pdf
Old 10-31-2016, 11:38 AM   #11
Rewards Points: 1,592
My guess in this cost contest is $867.93.
Old 10-31-2016, 01:09 PM   #12
These guys say call for quote:
http://www.deep-groove-ball-bearings...4b-p55561.html
2/3 of the Bing hits are in Japanese or Chinese.
Old 10-31-2016, 07:25 PM   #13
Rewards Points: 312
Thanks All.....I will take a "boo" at your links.
Old 11-01-2016, 08:38 AM   #14
100% sure on that part #?
I tried the NTN website to do a cross over and it would not come up.
Old 11-05-2016, 11:06 PM   #15
Rewards Points: 76
If you have a business, you might be able to get it from BDI (wholesale only).
Cheers!
supers05 is online now   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
Navane1 (05-03-2017)
wall removal... load bearing? interesting find jaxm211 Remodeling 6 08-07-2015 08:53 AM
Adding (framing) windows to non load bearing wall question schmaltzy Building & Construction 7 04-13-2015 09:39 PM
question on framing red86yota Building & Construction 7 12-18-2008 06:51 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Another Load Bearing Question - Modular Homes ch3howard Carpentry 2 08-17-2008 09:21 PM
