Self Tapping Screws - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree4Likes
  • 1 Post By captfl2x
  • 3 Post By captfl2x
Old 02-01-2018, 08:56 PM   #1
Rewards Points: 162
self tapping screws
I have seen on You-Tube self tapping screws penetrating and tapping holes in thick steel. It appears much thicker that my 7 ga. steel. I have purchased two different brands of self tapping screws at the "big box" stores. Both drill the hole and started to tap its way thru the plate but broke off beneath the screw head. This happened 4 times regardless of how careful I was with speed and pressure. I was using #8 x 1/2" and #8 x 3/4".
Where can I buy a good hardened screw that will perform as I need? I don't think that a case hardened screw will work?? I read that case hardened means that only the outside of the screw is hardened
captfl2x is offline   Reply With Quote
Old 02-01-2018, 09:45 PM   #2
JUSTA MEMBER
Rewards Points: 4,080
Re: self tapping screws
Do you have a Grainger supply nearby?
or try a place that specializes in nuts bolts, and screws.
ED
de-nagorg is offline   Reply With Quote
Old 02-01-2018, 09:49 PM   #3
retired framer
Rewards Points: 20,734
What ever you are screwing together can not have a gap between when you tighten the screw. You are trying to pull them together and it will break the screw or just stop every time.
Nealtw is offline   Reply With Quote
Old 02-01-2018, 10:03 PM   #4
Rewards Points: 1,584
Self tapping or self drilling
http://www.allpointsfasteners.com/FAQ.html
Old 02-02-2018, 08:57 AM   #5
Rewards Points: 7,606
Likely the screws you find at big box stores are sheet metal screws. They don't tap anything, they bend the sheet metal to the helix of a thread.
Search for TEKS 5 screws. Probably have to go to a place like Fastenal to find them, or online. Not sure if you will be able to buy two or three --- might have to buy a box, and I doubt they are cheap. Never used them myself, but they are supposed to be good for thicker steel plate.
SPS-1 is online now   Reply With Quote
Old 02-02-2018, 11:49 AM   #6
Rewards Points: 162
The last two screws that broke were TEK from the "big box store"; however, I do not know that those were "TEK 5". I assume TEK 5 means a "5" point. I'll also check out Grainger. I sent a message to http://www.allpointsfasteners.com/FAQ.html.
Thanks for the help.
de-nagorg likes this.
Old 02-02-2018, 01:32 PM   #7
Rewards Points: 7,015
I'm not sure they are designed for two layers of 7G. That is some pretty heavy metal. I would just drill the holes and be done with it.
If you can convert 1000s to gauge this page might help you: https://www.hilti.com/medias/sys_mas...OC_1577675.pdf
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-02-2018, 04:02 PM   #8
Rewards Points: 162
I only have one 7 ga. steel to go through. I am attaching a wire underneath the screw head to the plate.
Old 02-03-2018, 09:34 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... Step up to #10s, #12s, or even #14s,....
Old 02-03-2018, 10:16 AM   #10
Rewards Points: 162
Thanks to all for your suggestions/tips.
Old 02-05-2018, 05:52 PM   #11
Rewards Points: 162
I solved my screw breaking problem although it involves extra work. I first drill with a bit slightly under the diameter of the screw cutting tip. I coat the screw tip and threads with tap cutting oil before using an impact driver. I stop the driver before the head bottoms out and I use a small ratchet to finish the job.
de-nagorg, Nealtw and DannyDanDan like this.
Screws for Subfloor BigJimmy Carpentry 6 01-23-2016 01:31 PM
Regular floor screws in pressure treated wood Fred_ Building & Construction 17 07-18-2012 08:38 AM
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 09:26 AM
Construction screws - interior framing miamicuse Building & Construction 15 05-05-2012 05:56 PM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 02:08 AM
