Name Of This Piece Of Metal - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
Old 04-29-2020, 05:05 PM   #1
Rewards Points: 18
Name of this piece of metal
Hi all, I'm refinishing an old metal chair and taking it apart. i took these components off but i'm not sure what they're called so I can find a replacement. they're joined together by a bolt and a nut but i'm wondering what the actual metal lips are called?
quirkja is offline   Reply With Quote
Old 04-29-2020, 07:15 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,954
Re: Name of this piece of metal
post a couple of more times and you will be able to add photos
Old 04-30-2020, 08:11 AM   #3
Rewards Points: 18
thanks. do you know how many exactly?
Old 04-30-2020, 08:14 AM   #4
Rewards Points: 18
Old 04-30-2020, 08:34 AM   #5
retired framer
Rewards Points: 15,406
Originally Posted by quirkja View Post
Anytime now.
See below, go advanced and then find manage attachments and go from there to load pictures.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 04-30-2020, 08:40 AM   #6
Rewards Points: 18
https://ibb.co/023LWvW
Old 04-30-2020, 08:41 AM   #7
Rewards Points: 18
it needs to hold together two metal tubes of a mid-century metal chair that are 1/2" in diameter.
Old 04-30-2020, 10:16 AM   #8
Rewards Points: 1,296
It's called a ganging clamp.
HotRodx10 is online now   Reply With Quote
Old 04-30-2020, 10:41 AM   #9
retired framer
figure 7-14
Old 04-30-2020, 11:07 AM   #10
Rewards Points: 18
Thank you so much.
Old 04-30-2020, 11:15 AM   #11
Rewards Points: 18
do you know where i could buy a couple of these that are joining two pieces of rounded metal of approx 1/2" diameter?
Old 04-30-2020, 11:16 AM   #12
Rewards Points: 18
do you know where i could buy a couple of these that would work to join pieces of metal that are 1/2" in diameter?
Old 04-30-2020, 11:22 AM   #13
Super Moderator
joed's Avatar
Looks like a double cable clamp like I have seen on telephone drops to the house.
Old 04-30-2020, 11:29 AM   #14
retired framer
Thank you so much.
You might make them out of plumbers strap.
figure 7-14
Old 04-30-2020, 11:53 AM   #15
Rewards Points: 18
would that be able to hold the back of a chair to its base though?
