My New Harbor Frieght Stick Welder - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 11-22-2015, 05:57 PM   #1
Lectrishun
Cement_Frank's Avatar
Rewards Points: 58
my new harbor frieght stick welder
been a couple a year since I welded pipes
1/8" 6012
135a ac
3 1/2" pipe 1/4 wall galvanized
Welded it with my new harbor fright buzz box, should I turn up the welder a bit?
Cement_Frank is offline   Reply With Quote
Old 11-23-2015, 05:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
1/8" 6012
135a ac
Ayuh,.... Have ya got a fan blowin' on ya Frank,....
Galvanize will kill ya Dead,... Bad $h!t,....
google it,...
It don't look like ya ground the stuff off the pipe back far enough away from the weld area,....
Did ya see little white stringy thingys floatin' in the air just after ya flipped up yer hood,..??
That's Death,... if yer Lucky, ya might just get sicker than a dog, 'n only wish you were dead,...
Please be careful, or better yet, go find some steel that ain't galvanized to play with,...
I find tons, dumpster divin' myself,...
As for yer settin's,.... It's a new welder,... Play with 'em, 'n see what it does,.....
Is it a 120v, or 240v,..??
how many amps,..??
Bondo is online now   Reply With Quote
The Following 6 Users Say Thank You to Bondo For This Useful Post:
BigJim (11-25-2015), dd57chevy (11-26-2015), kwikfishron (11-23-2015), oh'mike (11-23-2015), r0ckstarr (11-30-2015), Windows on Wash (11-23-2015)
Old 11-24-2015, 08:37 PM   #3
Lectrishun
Rewards Points: 58
google it,...
how many amps,..??
Its one of these here http://www.harborfreight.com/welding...der-69029.html
I use a clamp meter to set my amperage. was running it about 135a. Draws 48a when its maxed.
I welded it outside, had a fan blowing the nasty smoke away. Didnt have a N95 respirator so I just held my breath during each pass. probably coulda cleaned it up a bit better. pressure tested it then put it back in service.
The Following User Says Thank You to Cement_Frank For This Useful Post:
oh'mike (11-25-2015)
Old 11-25-2015, 10:02 AM   #4
Rewards Points: 48
What's the pipe used for? Does it have a liquid or gas running through it? Or is it a round structural tube?
I'd say the welds are hot enough based on the info provided. I don't see any slag trapped in the toe lines of the weld beads, which is a good thing.
I've seen worse looking welds from guys who supposedly weld every day...
Looks like a really wide cap on that weld for 3.5" diameter 1/4" wall thickness pipe. There's some undercut and other issues I can see in your photo.
Whether or not you need to address those issues depends on how that pipe is being used.
A_DAB_will_do is offline   Reply With Quote
Old 11-25-2015, 10:22 AM   #5
Lectrishun
Rewards Points: 58
Its a water pipe, held 300psi in my test.
Old 11-25-2015, 10:25 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,642
google it,...
how many amps,..??
I found out the hard way about welding galvanized metal, no one told me about it. I was outside but it still made me sick as a dog. Didn't take but once for me, no more galvanize welding.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 11-26-2015, 06:44 AM   #7
Rewards Points: 996
iirc, drinking milk helps with galvanize poisoning.
Fix'n it is offline   Reply With Quote
Old 11-26-2015, 07:33 AM   #8
Ole Wood Worker
BigJim's Avatar
That is what I was told, it must have worked.
Jim
Old 03-17-2016, 05:48 PM   #9
bradleyshome's Avatar
Rewards Points: 114
Re: my new harbor frieght stick welder
I don't understand why people even use N95 respirators or similar kinds, holding your breath was probably better. They don't seal around your face so they are pretty much worthless. Get something once with replaceable filters that actually seals, safety should be the highest priority as you only have one life and its a lot better when you don't waste it because you wanted to save a bit of money.
bradleyshome is offline   Reply With Quote
Old 03-17-2016, 10:38 PM   #10
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
I dunno, we used N95 masks during the wildfires last summer and they made a huge difference. The el cheapos didn't do much but the N95s were great.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Nik333 (03-28-2016)
Old 03-28-2016, 01:46 PM   #11
Rewards Points: 4,220
You need one that fits your face; they come in different sizes. They do seal, if used properly. Find the size for your face shape & bend the metal around your nose. You can use a respirator if worried. They really should be fit-tested. ( Put mask on & a substance is sprayed, to see if you can taste it from the air)
The words mask & respirator are used interchangeably & are confusing.
http://ehstoday.com/industrial_hygie...ing-fumes-0301
Nik333 is online now   Reply With Quote
Handy tips for a happy house-- oh'mike General DIY Discussions 67 05-11-2014 07:39 PM
Stick welder receptacle MisterSteve Electrical 4 04-28-2012 04:17 PM
Powering a 240V stick welder with a portable generator. sdoss Electrical 2 05-19-2011 12:04 PM
MIG welding amakarevic Tools 28 02-20-2008 08:56 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 01:11 AM
