Metal Siding And Concrete - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By mark sr
Old 05-12-2019, 06:53 AM   #1
Rewards Points: 6
Metal siding and concrete
Building a house with 26 gauge metal roofing and siding. We have a 6 inch concrete slab. The metal siding will come down over the slab by about 4 inches. Any ideas on what I can use as a barrier between the metal and concrete to keep the metal from corrosion? Is there a paint or something?
Keylandt is offline   Reply With Quote
Old 05-12-2019, 07:17 AM   #2
retired painter
Rewards Points: 1,848
Re: Metal siding and concrete
Wouldn't there be roofing felt behind the steel siding?
Bondo likes this.
mark sr is online now   Reply With Quote
Old 05-18-2019, 06:22 AM   #3
Rewards Points: 560
Are you installing house wrap before the siding ? Run the wrap down far enough to cover the concrete then install the siding .
Porsche986S is offline   Reply With Quote
Old 05-18-2019, 07:20 AM   #4
Rewards Points: 472
Use rubber to avoid the galvanic reaction.
LOOK HERE
Let it Snow is offline   Reply With Quote
Old 05-21-2019, 01:49 PM   #5
Rewards Points: 1,356
i would just use a resisto style (or other brand) membrane on the concrete, they are sold in different width
carmusic is offline   Reply With Quote
Wood siding starting from concrete foundation DogBob Carpentry 0 07-12-2018 08:42 PM
Siding Not Meeting Poured Concrete Foundation Ironmanx Roofing/Siding 20 09-22-2015 09:44 AM
Siding meeting concrete pick1e Building & Construction 13 10-17-2012 03:15 PM
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 06:46 AM
help on verticle siding on concrete porch LeftyLucy Building & Construction 2 08-08-2009 09:03 AM
