Metal Sheds & Sliding Doors - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 06-28-2015, 10:28 AM   #1
NorPlan's Avatar
Rewards Points: 256
Hopefully I've Picked the Right Thread to Post my Query.. Since we're talking a Metal Shed.. I recently assembled an 8' X 6' Arrow Brand, Metal Shed.. I took Care to follow the Installation Instructions to the letter, the Problem is to Push / Pull the Sliding Doors on the Track.. One has to use the Two Handed Approach with great care in finding the sweet spot if you will without Yanking the BeeJeepers out of the Doors.. The Door Assembly comes with 2 Plastic Blocks to each door for the Top Track with 3 pr of holes in each block so as to adjust to close flush.. And only one sided U-Shaped Tabs to fit into the Bottom Track..
I'm asking for any Tips / Tricks to make the Doors Open / Close Smoothly as I said previously without Yanking hard on the Sliding Doors.. Cheers Thanks
NorPlan is offline   Reply With Quote
Old 06-29-2015, 08:30 PM   #2
Rewards Points: 1,760
When the last of the plastic slides broke, on one of the doors, on a metal shed I have, I replaced the slides with two of these:
http://www.lowes.com/pd_55273-76018-...en+door+roller
I'm going to replace both slides on the other door, as this fix made the doors work better than they ever had before.
You can try the same.
ktkelly is offline   Reply With Quote
The Following User Says Thank You to ktkelly For This Useful Post:
NorPlan (06-29-2015)
Old 06-29-2015, 08:48 PM   #3
NorPlan's Avatar
Rewards Points: 256
So if I get this Right each sliding door you replaced the 2 Plastic Blocks on Top that held 2 screw each .. Installed 2 Rollers instead ??.. Did You get them out of the Hardware Aisle at Lowe's ??: That is a Terrific Replacement Idea..
Old 06-29-2015, 09:04 PM   #4
Yup, you got it, and yes, I got them from the local Lowe's in the hardware section.
They are not a perfect fit, but man, they do work SO much better than those silly plastic blocks.
On my doors, the blocks had one hole, and the door had three adjustment holes in the metal.
Old 06-29-2015, 09:11 PM   #5
NorPlan's Avatar
Rewards Points: 256
At First I had issues with having the doors close flush so I could put a pad lock through the door handles.. My plastic blocks came with 3 pr of adjustable holes.. But as long as I can get those rollers up into the Track without to much difficulty .. It will definitely make a world of difference.. Thanks for the Tip
Old 07-04-2015, 02:53 PM   #6
NorPlan's Avatar
Rewards Points: 256
That's a Ditto to your Quote.. Made it intown on Friday, cruised the Hardware Aisle at Lowe's .. The Price $$$ was even better than online..lol.. Made the Modifications this morning .. World of Difference like Soft Butter on Bread.. Thanks Again for the Tip
Old 07-04-2015, 02:55 PM   #7
NorPlan's Avatar
Rewards Points: 256
@ ktkelly... That's a Ditto to your Quote.. Made it intown on Friday, cruised the Hardware Aisle at Lowe's .. The Price $$$ was even better than online..lol.. Made the Modifications this morning .. World of Difference like Soft Butter on Bread.. Thanks Again for the Tip
Old 07-05-2015, 04:10 PM   #8
Sometimes a little simple thing is a great improvement. Glad to hear it worked out for ya.
Made my head just a little bigger, says the wife.... :-)
Sliding glass doors for beach homes? kooshball Windows and Doors 6 07-14-2014 05:39 AM
Remedy for peeling cracking metal doors Dpowell Painting 1 04-14-2012 04:42 PM
Metal Doors Alarm maxebi Windows and Doors 2 03-14-2012 03:36 PM
Sliding closet doors and baseboard olli Carpentry 1 07-29-2010 06:47 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 05:01 AM
