Metal 24 X 48 Rack Bench Between Van Wheel Wells - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 01-02-2019, 09:50 PM   #1
Rewards Points: 74
metal 24 x 48 rack bench between van wheel wells
I am customizing a van for some camper functionality and need to fabricate a support bench between the wheel wells, but need it to be free standing and be easily removable. It will support as much as 500 lbs. I have this idea of some kind of U shared support bracket where the frame drops into and is held by gravity and a few pins.
Two questions.
(1) what metal and thickness should I use for the rack that will not bend or break?
(2) any idea for the adapter U base that will bolt on to van walls and be permanent .. is there already a component or hardware that does this for metal gauge of the prior question or will I need to fabricate it?
cyberpine is offline   Reply With Quote
Old 01-03-2019, 04:53 AM   #2
retired painter
Rewards Points: 1,736
Re: metal 24 x 48 rack bench between van wheel wells
I just used screws to attach the shelving to the body ribs in my old paint van but those shelves were never subjected to that much weight - some paint but mostly sundries.
mark sr is online now   Reply With Quote
Old 01-03-2019, 06:26 AM   #3
ZTMAN's Avatar
Rewards Points: 338
You could probably just use two Werner work platforms and call it done.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-03-2019, 12:56 PM   #4
JUSTA MEMBER
Rewards Points: 4,006
Two questions.
1. 1/4 inch thick angle iron, front/ back. 1 inch is fine, bolted to van panel.
2. Channel iron, the proper width needed.
ED
de-nagorg is online now   Reply With Quote
Wanting to build lumber storage rack, walls have metal studs 49Unbeaten Building & Construction 7 02-19-2018 04:55 PM
Carrier Blower Wheel Failures AzJeepguy HVAC 8 08-03-2014 03:09 PM
Craftsman Self-Propelled Mower Intermittent Power to Right Wheel (Left Wheel is Good) amodoko Tractors & Mowers 4 06-27-2014 03:50 PM
Microwave with metal rack? miamicuse Appliances 15 05-31-2014 08:49 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
