Looking To Get First Welder For Light Work Around The House - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By Bondo
Old 06-15-2016, 01:57 PM   #1
Rewards Points: 191
Looking to get first welder for light work around the house
So the wife finally listened to all my complaining about getting a welder and said that i can get one for fathers day.
experience - 0
needs - small welds on the trailer and random things around the house
looking for suggestions for something entry level and some what versatile.
welds dont need to be pretty for what i am working on. will be trailer and log splitter
rygar is offline   Reply With Quote
Old 06-15-2016, 09:20 PM   #2
Rewards Points: 18,052
Re: Looking to get first welder for light work around the house
Going to find it far cheaper, and come out better to just take it to a welding shop to get it done.
Buying the welder is only part of the total cost.
Running the wiring to run it, buying the rods or wire to do the welding, a Helmet will add to the total cost.
Old 06-16-2016, 12:08 AM   #3
Rewards Points: 56
Welding is not a cheap hobby by any means, but can be very fun. If you want to buy a welder, go for it and learn. Never hurts to have another skill.
I would look at either a Hobart from TSC or a Lincoln from Lowes/HD. These are very accessible for around $500. Depending on the wiring in your garage/shop, you may only be able to run a smaller unit.
jrp458 is offline   Reply With Quote
Old 06-16-2016, 06:53 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,.... Ya can't go wrong with a Lincoln wire feed mig,....
For 'bout $500. you can get a 140amp 120v welder,....
Don't cheap out, 'n buy a chinese welder, buy a brand name unit,....
r0ckstarr likes this.
The Following User Says Thank You to Bondo For This Useful Post:
oh'mike (06-24-2016)
Old 06-22-2016, 10:06 AM   #5
r0ckstarr's Avatar
Rewards Points: 82
What? My welds ain't pretty?
Truth is, I thought I was just going to be repairing some rust on the fenders of a car, so I got the cheap Harbor Fright Mig welder. The more I dug into the car, the more rust I found. I ended up regretting buying that welder and wished I would have gotten something better.
But, since I had it, I made use of it. I learned how to weld in high-school, and I think the Harbor Fright welder has a steeper learning curve than a good welder. You have to be pretty good with a good welder to get halfway decent results with the HF welder. In the end, I ended up brazing most everything else on the car.
The HF welder makes tons of splatter, no matter how you set it. The wire feeds at an inconsistent rate. It'll be going along just fine, and then suddenly slow down, then speed back up. I don't recommend it as a welder, but if you want a good spark show, this is it.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
Old 06-22-2016, 06:32 PM   #6
Bondo's Avatar
Ayuh,.... What's the picture Of,..?? a frame section,..??
Old 06-22-2016, 06:58 PM   #7
r0ckstarr's Avatar
Rewards Points: 82
That HF welder is much too small for a frame section. It's a radiator support. Here's the same support after grinding, re-welding, grinding, brazing, grinding, primer.
Old 06-24-2016, 03:59 PM   #8
Rewards Points: 191
i have an old metal filing cabinet. can i rip that apart and use that to practice with?
ended up going with this. i cheaped out becuase i had no clue how i would do or if i would continue, so i wasnt going to chance it with $500
https://www.amazon.com/ARKSEN%C2%A9-...s=p_4%3AARKSEN
great reviews, and a buddy at work said they used arksen welders at the school he was trained
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 11:32 AM
water mitigation around house tnprogrammer Building & Construction 4 02-22-2016 04:10 PM
Old House Wiring Traycam Electrical 14 01-03-2015 10:31 PM
How to grade away from house with little room to work with twopair2s3s Landscaping & Lawn Care 9 07-01-2014 12:13 PM
Blow toward fence or house in tight location ric in alberta HVAC 16 07-03-2012 06:27 PM
