How Not To Gusset - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 09-28-2015, 06:13 PM   #1
Rewards Points: 2,600
How not to Gusset
so basically, me trying to make something quick, i knew better, but here's the results. its called knifing. gussets should always be welded to the strong side of the member (in this case the sides of the square tube. there was so much force from torque (shade sail) that the tube basically collapsed right over the gusset. it probably would have survived if i ran this gusset the full length of the tube, but i didnt. i made new brackets that are way stronger, but this is a good lesson.
concrete_joe is offline   Reply With Quote
The Following User Says Thank You to concrete_joe For This Useful Post:
Fix'n it (09-28-2015)
diycoder's shed project diycoder Project Showcase 53 06-13-2017 04:06 PM
Best way to fasten wood gusset miamicuse Building & Construction 2 02-17-2012 05:18 AM
Attic catwalk - step over HVAC duct M3 Pete Carpentry 10 12-01-2011 11:01 PM
