How To Cut The Bottom Of Metal Lantern - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree4Likes
  • 1 Post By de-nagorg
  • 1 Post By Gregsoldtruck79
  • 1 Post By Colbyt
  • 1 Post By Nn2036
Old 07-27-2018, 10:49 PM   #1
Rewards Points: 66
How to cut the bottom of metal lantern
I want to change the big lantern into a chandelier so I need to cut the metal bottom of the lantern .
https://www.potterybarn.com/products...=PIPRecentView
What tool I can use to do it or who are the professionals should I ask to do it for me?
Nn2036 is offline   Reply With Quote
Old 07-27-2018, 11:23 PM   #2
retired framer
Rewards Points: 20,276
Re: How to cut the bottom of metal lantern
Just use something like this.
Old 07-28-2018, 06:14 AM   #3
Rewards Points: 6,995
If it is used I would probably add some water before I cut it. Kerosene is no where near explosive as in gas fumes but why take a chance.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 07-28-2018, 08:10 AM   #4
Rewards Points: 1,480
I'm a hack so I'd use a Hack Saw with a 32 tpi blade.
https://en.wikipedia.org/wiki/Hacksaw
Old 07-28-2018, 08:17 AM   #5
JUSTA MEMBER
Rewards Points: 4,004
Well I must be dumb, I need to know why you need to cut it, before I will say how to.
ED
joecaption likes this.
de-nagorg is offline   Reply With Quote
Old 07-28-2018, 08:27 AM   #6
Rewards Points: 1,858
I am even more inquisitive. What is going to support the 4 structural vertical rails of the lantern, once the bottom of it is cut off ?
de-nagorg likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 07-28-2018, 09:25 AM   #7
oops. did not look at the image and assumed it was a real one.
I suspect he will merely cut the sheet metal and leave the bottom frame intact. I sorta think he could buy one cheaper and much easier. I know I've seen that style somewhere.
Colbyt
Old 07-28-2018, 10:58 AM   #8
Rewards Points: 66
Just the sheet metal so light can shine down.
I have looked at many similar style lamp and none I like.
Nealtw likes this.
Old 07-28-2018, 05:09 PM   #9
JUSTA MEMBER
Then I would get a metal cutting " hole saw", and X for the center of the panel.
Then mount the fixture securely in a holding clamp of some kind.
And chuck the " hole saw" in a variable speed drill, and saw the panel out in a circle.
ED
Old 07-28-2018, 05:13 PM   #10
retired framer
I think this is still the easiest just draw lines on the bottom 1/2" from the sides and cut the lines.
Metal Edging and Odd Connection Point on Wall cloves Tiling, ceramics, marble 4 06-21-2014 04:34 PM
metal sheathing DiegoJames Electrical 2 07-01-2013 06:59 AM
Recommendations for roof type when reroof daluu Roofing/Siding 24 12-07-2012 02:23 PM
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 06:37 AM
cutting the bottom of a metal door frame for flooring redsey Flooring 1 07-27-2010 08:55 AM
