How To Bend 9gauge Galvanized Metal - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree5Likes
  • 2 Post By Bud9051
  • 1 Post By Nealtw
  • 1 Post By FrillyLily
Old 06-20-2018, 07:56 PM   #1
Rewards Points: 202
How to bend 9gauge galvanized metal
I have some 9 gauge stakes, about 500 of them actually, that I need to bend a loop into the top of so I can hang a small metal tag from. (Plant labels) and I really underestimated how difficult it would be to bend this stuff! It is is alot stronger than I thought! I used bolt cutters to cut each piece to the length I needed and I have the tags made, just need to figure out how to bend a small loop into them. Maybe about 3/4 of an inch or so? Any ideas please! Thank you!
FrillyLily is offline   Reply With Quote
Old 06-20-2018, 08:52 PM   #2
Rewards Points: 1,566
Re: How to bend 9gauge galvanized metal
Is the loop you need similar to this pictured that these wires have, with the exception you need the loop completely closed?
Old 06-20-2018, 08:59 PM   #3
Rewards Points: 6,152
Not exactly sure what your end result needs to be, but drilling a hole in a metal pipe or solid shaft and then wind your wire around it. That wan you have the long end for leverage.
Bud
SeniorSitizen and Nealtw like this.
Bud9051 is offline   Reply With Quote
Old 06-20-2018, 09:03 PM   #4
retired framer
Rewards Points: 20,676
Cut a slot in the end of the pipe. insert and wrap the slot will allow you to remove it.
Hopefully you have a vise to hold the pipe.
Bud9051 likes this.
Old 06-20-2018, 09:07 PM   #5
Rewards Points: 202
Similar to the pic above, but more to the side a little so the tag would hang.
https://www.amazon.com/GardenMate-10...62499296&psc=1
Nealtw likes this.
Old 06-20-2018, 09:08 PM   #6
Rewards Points: 202
I do have a large vice.
Nealtw likes this.
Old 06-21-2018, 05:35 AM   #7
Rewards Points: 1,980
Gregsoldtruck79 is online now   Reply With Quote
Two Questions: halex 90 degree connectors; grounding/wire in metal boxes tooltime88 Electrical 3 05-19-2018 12:56 PM
Grounding Metal Boxes and Outlets - Confused by Something Simple ALFisher Electrical 42 04-28-2015 12:14 PM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
