How To Attach Metal Plate To Cinder Wall - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree5Likes
  • 1 Post By hkstroud
  • 4 Post By KoenBro
Old 03-09-2019, 06:46 PM   #1
Rewards Points: 20
How to attach metal plate to cinder wall
I have my house number on a 26 x 8 x 1/8" steel plate, and need to attach it to my mail box, which is a 26"x 26" square post made of cinderblock.
My wife does not want the metal plate to be drilled through, so I need to attach some anchors behind it. The plate would float some 1" in front of the wall.
I can weld, have a bandsaw, and can do some minimal fabrication. Can anyone suggest a way to do this?
Thought of drilling four 1/4" holes into the cinderblock and put in 1/4" rods (with some cement), that would stick out 1". Then weld 1" long pieces of 1/2" ID tube. Not sure how to attach it tot he rods though.
Any ideas? Thank you!
KoenBro is offline   Reply With Quote
Old 03-09-2019, 07:00 PM   #2
retired framer
Rewards Points: 20,278
Re: How to attach metal plate to cinder wall
What ever you use to attach to the post aim for the mortar joint
Do not use flat bottom gables with scissor trusses.
Old 03-09-2019, 07:04 PM   #3
Property Mgt/Maint
Rewards Points: 6,522
3M makes a super strong double stick tape. It is used to hold display panels on semi-trucks. You could tap-con (2) 1" square tube rails to the mail box blocks, then use the double stick tape to hold the plate on the tubing.
3M VHB tape
https://www.3m.com/3M/en_US/vhb-tape...SAAEgJ7OvD_BwE
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-09-2019, 07:51 PM   #4
Rewards Points: 20
What solution do you recommend for the back of the steel plate?
Old 03-09-2019, 08:00 PM   #5
retired framer
You might copy these hanger for mirrors, it sits in the bottom one and the top one just slides down to hold it in place.
Old 03-10-2019, 08:36 AM   #6
Property Mgt/Maint
If this was directed at my comment it helps to use the quote feature to avoid confusion.
I will try again. Take 2 lengths of 1" square steel (or SS would be better) cut to about 24" long. Then Tap-Con the bars to the block.
You will need to drill a larger 3/4" hole on the top of the bar that will be clearance for the socket needed to drive the Tap-Con. And then a smaller hole just large enough to clear the Tap-Con screw size through the bottom of the bar. I would probably use 3 screws per bar. Once your bars are in place, apply the 3M VHB tape to the bars, then stick the Address plate to them. The metal surfaces will need to be clean, de-greased, and sanded lightly. Take precautions to install straight and exactly where you want it. Once the tape has made contact, there will no moving it.
Most would not consider tape in this application, But this 3M VHB tape is amazingly strong. Read the application info from the link above.
Old 03-12-2019, 05:54 PM   #7
hkstroud's Avatar
Rewards Points: 5,928
Purchase a 1/6 treated deck board. Cut to length (24"). Rip off about 1 1/2" strip from each edge with saw blade at a 30 degree angle. Lay all three pieces on back of house number plate. Epoxy the top and bottom strips to plate with JBweld (the narrow side). Paint with black paint. Slide center piece out toward the end.
Drill and counter sink three or maybe four holes in center piece. Paint black. Mark and drill cinder block. Paint the other side of center piece. Mount center piece with deck screws and plastic anchors.
Mount house number by sliding on from the side.
Nealtw likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
KoenBro (03-17-2019)
Old 03-17-2019, 06:51 PM   #8
Rewards Points: 20
OK I am getting ready to mount. I will drill some 3/8" holes into the cinderblock and put some 1/4" steel rods in.
What kind of cement (or grout?) should I get from Home Depot to secure the rods into the cinderwall?
Old 03-17-2019, 07:26 PM   #9
hkstroud's Avatar
How are you going to mount?
Harold,
Old 03-18-2019, 07:56 AM   #10
Property Mgt/Maint
Anchoring cement. You can buy it in a caulk tube
Old 03-20-2019, 12:07 AM   #11
Rewards Points: 20
I drilled two 1/4 holes into the cinderwall.
Then welded two 3- long pieces of 1/4 rod to the back of the plate on the upper half, and slid 1/2 long segments of 1/2 tube onto them to act as spacers, and also welded two long pieces of 1/4 rod on the back, towards the bottom to act as spacers. Then hammered the long rod segments into the wall, a slight spacing mismatch ensured friction fit. It does look good.
SPS-1, Yodaman, Nealtw and 1 others like this.
Old 03-20-2019, 06:37 AM   #12
hkstroud's Avatar
Nice.
Harold,
KoenBro (03-28-2019)
Old 07-24-2019, 03:33 PM   #13
Rewards Points: 578
Or get a tube of adhesive caulk to mount the plate to the cinderblock. There are caulks made for use with stone and they should work with the cinderblock as well.
Calson is offline   Reply With Quote
Old 08-04-2019, 06:04 AM   #14
Rewards Points: 12
Make sure you fill the cinder blocks. I would put rebar down the inside attached to the base with epoxy and fill the cells with non shrink concrete or Quick Rok. This will give you a very soild backing behind the blocks the drill holes with the supplied bit for tapcon screws ( which they have in Flathead or hexhead which ever you choose), this should solve the Issue. BigD9105
BigD9105 is offline   Reply With Quote
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Top plate for frame wall, quick ? NEW-B Building & Construction 7 03-18-2011 08:33 PM
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 10:31 AM
