How To Aluminum Weld - Metal Fabrication - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree2Likes
Old 04-03-2017, 12:15 PM   #31
Rewards Points: 12
Re: How to Aluminum Weld
Welding aluminum does not need to be heated if your are using mig or tig. Welding on aluminum you need to clean the aluminum oxide off right before welding. Use a purpose cleaner for it. They work best. Iso rubbing alcohol worls ok or use a stainless steel wire brush. Anything else wont work. Any cheap AC/DC mig or tig welder will work. They just need to be sealed not for super strength. Practice on same sized aluminum first because buring throigh on aluminium is not the same as steels. If you inly have a few spots to fix take it to an experienced shop. Cheaper that way and they take the blame if its not done right.
If you have more questions just reply ive welded alot of aluminum.
Sent from my Nexus 6P using Tapatalk
crash525 is offline   Reply With Quote
Old 04-03-2017, 12:16 PM   #32
Rewards Points: 12
Originally Posted by BigJim View Post
Thanks Fix, I think I may have already messed up, Bondo said not to put sealant on it and I did. I took the pressure off that spot and placed it in two other places but with a wider area to lessen the PSI pressure, so I am not worried that the crack will widen.
After buying so many smaller things like new tires etc, the funds are getting slim. LOL The fellow wanted $150 just to come out to the house. I know people have to make a living and I probably would charge the same thing in his shoes. I figure if I took the pressure off that spot and then sealed the crack to keep water out, I should be good to go.
To stop a crack take a small drill bit and drill each end of the crack.
Old 06-26-2017, 12:37 PM   #33
Rewards Points: 6
To do a proper aluminum weld I recommend using a proper shielding gas. Oxygen mixture for example and Sulfur hexafluoride is also very recommended.
You might want to think about using arc welding as well. Some reasons why:
http://roshmetal.com/advantages-of-arc-welding/
The ease of use and the low price might be the main reasons why. At least the ones I consider when working.
MarkoG is offline   Reply With Quote
Replacing Aluminum single sash windows to Vinyl steppinthrax Windows and Doors 11 12-18-2014 08:42 AM
Hot Water Anode: Aluminum vs Magnesium zootjeff Plumbing 4 12-14-2012 03:41 PM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 11:19 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
