Galvanized Tank - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 08-02-2015, 05:20 PM   #1
Rewards Points: 112
Galvanized tank
Would it be ok to build a smoker/grill from a galvanized tank if I did a complete burn on it? It is an old water tank. I have built a lot of them. I just never came up on one of these to build for a customer. I was wanting to check before I told them yes or no. Thanks in advance.
sirweldalot is offline   Reply With Quote
Old 08-03-2015, 07:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,612
I imagine if it were seasoned properly it won't much matter.
Old 08-03-2015, 08:40 AM   #3
GrayHair's Avatar
Rewards Points: 1,358
This is a common question on BBQ forums, resulting in plenty of opinions but few facts. Having used an acetylene torch and an arc welder on galvanized steel, I can tell you that both fumes and residue are nasty.
While the temperature difference between cutting/welding and grilling/smoking is large, will the temperature of the zinc coating remain below the point of gassing? The is also the chemical composition of, primarily, the galvanizing. What else is in there besides zinc?
For my personal use, I wouldn't. For someone else, AIN'T NO WAY! JMO.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
The Following 4 Users Say Thank You to GrayHair For This Useful Post:
123pugsy (08-13-2015), bofos2002 (08-13-2015), sirweldalot (08-03-2015), Windows on Wash (08-04-2015)
Old 08-03-2015, 09:04 AM   #4
Great info there.
Old 08-04-2015, 08:53 AM   #5
Rewards Points: 4,406
That's definitely a good reasoning...
ron45 is offline   Reply With Quote
Old 08-04-2015, 11:48 AM   #6
Low Slope Roofing
Rewards Points: 114
Welding/cutting galvanized will poison you if you are exposed to it for to long. No I wouldn't make a cooking device out of and galvanized metal. I doubt you will ever "burn" the galvanizing out.
1985gt is offline   Reply With Quote
Old 08-04-2015, 06:14 PM   #7
According to another thread here in this forum it just might be possible. All you need to do is add some fire rated material, now how long to plan to cook with this thing, 1 hour, 2 hour, 4 hour..?
Old 08-13-2015, 05:32 PM   #8
Rewards Points: 6
IMHO making a smoker/cooker out of galvanized is a real bad idea. I'm not sure if you can do a "complete burn" that is actually complete enough. I wouldn't take a chance with my family and damn sure not someone else's. I've made a living as a welder and as careful as I am, I have been pretty sick a time or two messing with that stuff. Do both of you a favor and find some other material.
bofos2002 is offline   Reply With Quote
Old 08-23-2015, 04:13 PM   #9
Rewards Points: 2,600
no, do not cook in galvanized tanks, they will give off bad fumes, and constant contact with it is also not good long term.
what you can do though, you can strip the galvanizing off with a muriatic acid. then paint the outside with hi-temp bbq paint. you can also paint the inside with hi-temp paint, but run a hot grill for a hr or so to burn off anything that wants to burn off. std steel will rust inside out on a grill like this, but you could possibly line the charcoal area with some stainless sheet, etc.
concrete_joe is offline   Reply With Quote
Old 08-23-2015, 06:17 PM   #10
Rewards Points: 7,538
I don't know for sure if its safe. But I don't recall ever seeing a purchased grill where the specs include galvanized steel. I have seen them spec stainless steel, painted steel, ceramic coated steel, but I don't recall seeing galvanized steel.
SPS-1 is offline   Reply With Quote
Old 08-23-2015, 08:50 PM   #11
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... I do know weldin' galvanized steel will make ya sicker'n a dog,...
get a nose fulla the crap, 'n it'll outright Kill ya,....
problem with well presure tank nanuk Plumbing 3 05-22-2013 11:12 PM
new septic tank jason41987 Plumbing 11 04-20-2013 01:16 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
hot water tank help needed psp Plumbing 2 08-22-2010 02:46 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
