Fabricating An Aluminum U Channel For Garden Fountain - Metal Fabrication - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree7Likes
Old 08-17-2017, 05:25 PM   #16
Rewards Points: 616
Re: Fabricating an aluminum U Channel for garden fountain
Well, they got 'er done but she ain't gonna win no beauty contests! Definitely not the prettiest I've ever seen.
Need some cleanup work on this. Can you guys suggest how to clean this up? Will fine grit sandpaper, one direction scrub, help get back that brushed aluminum look or at least help smooth over this?
I'm just trying to get a non reflective luster finish that is consistent throughout the entire piece.
homeimproverjoe is offline   Reply With Quote
Old 08-18-2017, 04:57 AM   #17
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... Sand/ grind it out with a flap-disc on an angle grinder, then brush it with a ssteel brush on yer grinder,....
Old 08-18-2017, 08:20 AM   #18
Rewards Points: 1,289
Unfortunately the rest is not "brushed", so brushing it won't match either. Might be an improvement, but won't match. Polishing it (each grit finer than the last, then buffing) then letting it naturally patina would be a closer match...
XSleeper is offline   Reply With Quote
Old 08-18-2017, 08:38 AM   #19
Rewards Points: 2,906
You could take to someone that does blasting it could be made to look like new. Different medium blasting materials will give different looks.
ClarenceBauer is offline   Reply With Quote
DIY Driveway Channel Drain installation (Slope Issue) HTFreak General DIY Discussions 1 08-02-2016 09:45 PM
F or J Channel for slanted aluminum Soffits? joshhemming Roofing/Siding 11 04-13-2016 03:06 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
