Electric Oil Heater Repair - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 03-31-2015, 11:27 AM   #1
Rewards Points: 12
Electric oil heater repair
Not sure where to post this, but hopefully I can get some useful advice.
I picked up a fairly new looking electric oil heater. It looks like a radiator.
The only thing wrong with it is that it has a small pin hole in the side. When it heats up, the oil bubbles out the hole.
Would jb weld work to repair it or would it need to be welded. I do have access to a welder that my dad has.
Pelonis Electric Radiator Heater https://www.amazon.com/dp/B009QEXXJ6..._A5Pgvb0PT6JV1
Proverbs‬ *16‬:*20‬
Joshual11 is offline   Reply With Quote
Old 03-31-2015, 05:38 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... I'd try a tiny rubber gasketed roofin' screw,....
Probably oughta just Toss it, 'fore ya burn yer house down though,....
Old 03-31-2015, 08:46 PM   #3
Rewards Points: 996
clean down to metal. scuff area, JB weld will do it.
Fix'n it is offline   Reply With Quote
Electric Tankless Water Heater Vs. Gas Tank Water Heater hellohello Plumbing 7 11-26-2013 02:48 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 12:08 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
