Drilling With Water ? - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree3Likes
Old 10-13-2018, 09:54 PM   #1
dd57chevy's Avatar
Rewards Points: 2,808
Drilling with water ?
I'm working on a modification to a snow blade & had to drill some 25/32" holes through mild steel with a cheapo HF drill press .
I'm an average welder but have always had problems dulling bits .
Went to Acme tools & plunked down $18.00 for a bit & asked the guy about drilling steel . He said :
1. Stable , flat surface support .
2. Steady , light to medium pressure (feed) .
3............& use WATER to cool the bit !
I went home thinking it over & decided to give it a try . I already had one of those old restaurant style ketchup squeeze bottles so I put some water in it & started drilling ........... It worked like a charm ! Drilled 5 holes in a jiffy !
Am I the only guy who didn't know this ?
dd57chevy is online now   Reply With Quote
Old 10-13-2018, 10:50 PM   #2
Rewards Points: 6
Re: Drilling with water ?
Water is a new one to me, too. I usually use cutting oil and have found cobalt bits to be superior for drilling into even hardened steel. The angle ground on to the business end of the drill bit matters, too--wood and metal do not share optimal angles.
w0j0 is offline   Reply With Quote
Old 10-13-2018, 11:17 PM   #3
Rewards Points: 62
Been using the water method for years works good for me. Make sure you keep the drill cleaned as some parts rust very quickly.
dd57chevy likes this.
ClarenceBauer is online now   Reply With Quote
Old 10-13-2018, 11:18 PM   #4
Rewards Points: 6,836
Oil or water both provide cooling and heat is the enemy of all drill bits. As w0j0 said, the angle of the bit is important, although I never really mastered achieving it. A good friend worked in the machine shop my company had and tried to teach me how to drill different metals. He was good, I was no so.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 10-13-2018, 11:33 PM   #5
retired framer
Rewards Points: 460
Never understood why they call them high speed when slow is the only way to go.
Old 10-14-2018, 02:47 AM   #6
Rewards Points: 2,288
Add a little soluble oil to the water to inhibit rust.
Old 10-14-2018, 08:58 AM   #7
dd57chevy's Avatar
I guess part of the problem is it takes kind of a steady hand . I believe I would get started & then bear down (try to speed up the feed) . The guy said another thing that stuck in my head : "Let the bit do the work....."
Bingo !
I was also using 5-30 motor oil . Not as good at dissipating heat AND actually providing unwanted lubrication !
Old 10-14-2018, 09:11 AM   #8
Rewards Points: 996
interesting. I will have to try it.
if i am not here, it means i cannot long in. but i can read.
Fix'n it is offline   Reply With Quote
Old 10-14-2018, 10:19 AM   #9
You and many others tried that and I suspect that's why cutting oil was developed.
Old 10-14-2018, 12:02 PM   #10
Rewards Points: 18,068
The bigger the bit the slower the speed.
Run it to fast and the material your trying to drill becomes "work hardened", so it becomes even harder to drill.
On bigger drill bits like that I grind back some of the material on the back side of the cutting surface on the drill so there's less friction.
Like the X or XR shown in this picture.
https://www.google.com/search?q=dril...vQefW7_h_zUiM:
Old 10-14-2018, 09:19 PM   #11
Rewards Points: 1,814
Yep, in machine shops for large scale lathe, milling and drilling ops, some 'soluble oil' is mixed with water and used to cool the bits. Forms a milky white solution. It's generally collected in a pan and recycled to keep it off the floor. Haven't seen it for sale in home centers though.
ChuckF. is online now   Reply With Quote
Old 10-14-2018, 10:09 PM   #12
For a small amount that an occasional DIY'er might need, try a auto supply to purchase a pint of radiator rust inhibitor oil and mix with water. At one time Prestone was available and Gunk brand may be as well. I believe I read that a water to oil ratio of 10:1 or 15:1 would work real well.
Old 10-15-2018, 08:58 AM   #13
Rewards Points: 2,800
As the water boils away due to the heat created by drilling, the metal work and the bit will remain around 212 degrees F. Watch for the boiling to stop (the water is all gone) while you are still drilling, then add more water.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 10-15-2018, 10:35 AM   #14
Rewards Points: 62
I just placed my drill stand in a drip pan than I use a small tube that is connected to my water supply with a small control valve to control water flow this tube can be moved to the point of the drill bit.
The water than goes to the drip pan which has a drain line.
Old 10-16-2018, 04:46 AM   #15
Rewards Points: 1,144
CNC machine shop owner here. Questions?
Yes, water can work to remove heat. No, we don't use straight water in our operations.
Typically when I see people fighting with hand drilling, there are a variety of things going on.
1. harbor freight drills? Yeah right. maybe for a few holes in Al. No go in steal.... I don't care if you are injecting straight cutting oil at 1000psi, those drills are junk. Quality drills make quality holes. Quality drills are NOT that expensive!!! Yes, the fancy ones we use are, but you can't even use them in a hand drill anyway.
2. EVERY PART OF OUR BEING relies on FEEDS AND SPEEDS! I watched a guy burn up a hand full of drills in a flash trying to run his drill on warp speed in steel. I simply reached over and put his drill in first gear and told him to give that a go. He drilled 20 holes dry with the same drill..... The calculations are NOT complicated and they are not magic.
Just like endmills, drills are NOT all the same. There are different point geometries, different point angles, reliefs, rakes, etc, etc. Then there are different materials. Believe it or not, harder is not always better. Harder means brittle. If the flutes are chipping, you need to examine the operation parameters or the drill.
If a drill is burned, it is probably junk because it has knocked the heat treat out of the drill point. However, I commonly walk them over to the grinder in a pinch and touch them up and run them until they die. No, the point won't last as long, no they won't give you the precision of new. The way to properly keep drills going is the resharpen when dull, not burned up. Most small drills are not worth this effort but I assure you, though I just grind mine by hand, they make a sharpener and it will save your butt many times in a pinch!
NO, I would NEVER hand grind a drill to be used in a machine ever. That is a recipe for scrap parts. I am referring to hand drilling. If you don't precision sharpen a drill, the flutes will not be the same and the drill will pull in the hole likely causing the hole to be a bit off. If your operation requires a precise hole, precision sharpen or get a new one.
viper is offline   Reply With Quote
2nd Floor Bathroom Leak KenOhio76 Plumbing 7 01-09-2018 03:10 PM
Water Heater Issues clark77494 Plumbing 12 10-09-2017 05:32 PM
Can't drain electric water heater dubina Plumbing 35 08-02-2017 09:07 PM
Help with hot water katiejosh811 Plumbing 13 12-28-2016 06:52 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-09-2014 12:40 AM
