Dont Have It, Make It - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 02-12-2015, 09:04 AM   #1
Rewards Points: 2,600
Dont Have it, Make It
doing some brakes on car, stupid integrated parking brake means spiral caliper piston. i dont have the real tool nor do i care to buy it, so i made something that allowed me to get the piston back down. ~60k miles on the rear pads, 1st time replacing these ones, my last time too, car is being sold.
but hey, here's an idea if you run into this problem. i simply measured between the "holes" in the piston face and then added some pins (welded in place) to a ~6" piece of scrap. the pins stick out to about the depth of the "holes" in piston. i engage the piston with tool and with one hand grip the caliper and hold tool tight on piston face with thumb, i turn it with other hand. now what seem odd is, at one point it just seemed like the piston was spinning but not moving down, so i used the help of a C clamp to add some "push" while i turned the piston, and that did the trick for that last 1/8" or so i needed to be able to get the caliper back over these new thick pads. and to note, all the turning is with fluid valve open, i'll do final brake bleed later.
concrete_joe is offline   Reply With Quote
The Following User Says Thank You to concrete_joe For This Useful Post:
Windows on Wash (02-13-2015)
Old 02-13-2015, 10:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Necessity is the mother of all invention.
I bought the kit from Harbor Freight, but then again...I don't have a welder or those skills.
Everything working right after the brake swap?
How to make large doorway in load-bearing concrete block wall? hstraf Building & Construction 10 12-12-2013 01:48 PM
How to make up an Inch? vmcmahon Tiling, ceramics, marble 36 11-18-2013 08:44 PM
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 09:39 PM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 10:48 AM
FREE plans/instructions for easy to make Magic Box! DangerMouse General DIY Discussions 5 07-23-2009 04:14 PM
