Distressing Angle Iron - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree13Likes
  • 2 Post By SPS-1
  • 2 Post By Bondo
  • 1 Post By Nealtw
  • 2 Post By mark sr
  • 3 Post By lenaitch
  • 3 Post By Nealtw
Old 03-05-2019, 03:59 PM   #1
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,244
Hi....
I've got a great distressed table.... but I'm going to have to have some custom angle braces welded up for me... probably from hardware store stock.
Any ideas on how I can distress these...the more distress the better.
Chemical distressing or any other mechanical ideas.
Any ideas as to the stock I might want to try and find, plated/mild steel that might distress better.
Thanks for any leads/ideas.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-05-2019, 04:06 PM   #2
Rewards Points: 7,546
Re: Distressing Angle Iron
Try going to YouTube and search "Rat Rod patina"
Myself, I don't like them, but there is a genre of hot rod that is supposed to look old and rusty.
MTN REMODEL LLC and Nealtw like this.
SPS-1 is online now   Reply With Quote
Old 03-05-2019, 04:17 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,..... How big/ heavy are these angle braces gonna be,..??
As for distressed stock, size matters,......
If ya need 1, 1/2" angle iron,..... ole bed-rails from a scrap heap are good stuff,.....
Go to a scrap yard, 'n see if they'll sell ya some ole rusty steel in whatever sizes, 'n shapes ya what,.....
Once the brackets are built, clean 'em up, 'n finish how ever ya want,......
For agin' new steel,.... grind some spots with an angle grinder, spray the whole thing with vinegar or Clorox, let dry, then wash off,.....
Instant Rust,....
Bondo is online now   Reply With Quote
Old 03-05-2019, 04:30 PM   #4
retired framer
Rewards Points: 20,392
Find some well used pieces from the scrap yard.
MTN REMODEL LLC likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 03-05-2019, 04:44 PM   #5
retired painter
Rewards Points: 1,776
Instant Rust,....
That's what kind of what I was thinking, sand the steel, coat it with bleach, let it set and then rinse/wash it off.
Bondo and MTN REMODEL LLC like this.
mark sr is offline   Reply With Quote
Old 03-05-2019, 09:16 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 2,174
Yell at it and call it names.
Bondo, MTN REMODEL LLC and Nealtw like this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 03-05-2019, 09:24 PM   #7
retired framer
That only works with the wife.
Angle stop seized on iron pipe Chriscomp Plumbing 5 07-17-2012 09:43 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
Wooden Top For Wroght Iron Railings ThomF Carpentry 10 11-01-2007 11:41 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
