Cutting Hardware Cloth - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By Fix'n it
Old 08-22-2018, 07:40 PM   #1
Rewards Points: 70
Cutting hardware cloth
I need to cut some 1/2" hardware cloth into a few longish strips (6' to 9'). I could do it with tin snips, but that would be tedious. The first thing that occurs to me that would be easier is an abrasive blade in my skil saw. Is that a good approach?
I might also need to move up to 1" hardware cloth or 16 gauge welded-wire fencing. How would you best cut that?
mx13 is offline   Reply With Quote
Old 08-22-2018, 07:42 PM   #2
retired framer
Rewards Points: 20,238
Re: Cutting hardware cloth
That will work, gloves and glasses.
Old 08-23-2018, 04:38 AM   #3
retired painter
Rewards Points: 1,714
I've always used tin snips or aviation shears. I'd be concerned that the blade might try grab/rip some of the wire along with the cut.
mark sr is offline   Reply With Quote
Old 08-23-2018, 07:38 AM   #4
Rewards Points: 1,472
The abrasive blade should work. If it comes in a roll as often does, I would some way clamp it between a couple of 1x4's to flatten, use a straight edge as saw guide and set the saw depth just enough to cut the wire thickness. Let us know what works for you. I need to cut a couple of pieces myself.
Old 08-23-2018, 07:40 AM   #5
Rewards Points: 996
cut off wheel in an angle grinder.
ClarenceBauer likes this.
Fix'n it is offline   Reply With Quote
Old 08-23-2018, 11:26 AM   #6
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,232
the angle grinder with a metal cut-off blade is my favorite
GO TO tool for cutting any kind of metal fence material.
Johnny_inFL is online now   Reply With Quote
Flooded_drywall cutting questions_suggestions tearitup Drywall & Plaster 34 09-01-2017 09:50 PM
Cutting tabs at round pipe end to connect to box amakarevic HVAC 7 12-26-2013 02:38 PM
Cutting hole for outlet in tile RichardZ Tiling, ceramics, marble 5 12-18-2013 09:18 AM
Growing A Willow From A Cutting...How/When To Prune? JL-KA Landscaping & Lawn Care 2 10-09-2013 04:24 PM
regular zinc coated steel hardware with ACQ treated lumber dumbunusedid Building & Construction 3 08-12-2008 07:20 PM
