Cutting Down Nails Which Stick Out - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree14Likes
  • 4 Post By de-nagorg
  • 1 Post By de-nagorg
  • 2 Post By Yodaman
  • 3 Post By Bondo
  • 2 Post By Domo
  • 2 Post By ken33xx
  • 1 Post By Oso954
Old 03-24-2019, 10:22 PM   #1
Rewards Points: 256
Cutting Down Nails which Stick Out
I noticed several nails sticking out from the neighbors wall. It's in the trade alley.
The house is a rental and I have yet to get in contact with the owner.
The renters don't want me to push the nails back.
I'm thinking it might be easiest to cut the nails.
Any help would be appreciated.
Cutting Down Nails which Stick Out-1.jpg   Cutting Down Nails which Stick Out-2.jpg
ken33xx is offline   Reply With Quote
Old 03-24-2019, 10:28 PM   #2
JUSTA MEMBER
Rewards Points: 1,182
Re: Cutting Down Nails which Stick Out
Rental: Do not touch it.
Alert the owner, tell them that this a safety hazard, someone can get cut, pierced of maimed by them.
I am a BTK AMPUTEE, because I stepped on a nail.
Got gangrene, and had to have my foot and 10" of my leg removed to stop it from spreading.
Protruding nails are a danger.
And the owner of this property is responsible for all concerned persons safety.
ED
de-nagorg is offline   Reply With Quote
Old 03-24-2019, 10:36 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 766
Yup, not your property. Get the tenants to contact the property owner. If it was my place to worry about, a set of lineman's pliers and a good grip would do the trick or a nail cutter (don't know how common they are now - farriers use them).
Hmm, image doesn't seem to be showing.
http://www.farrierproducts.com/field...ailcutter.html
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 03-24-2019, 10:42 PM   #4
JUSTA MEMBER
If this a shared causeway, and you use it, you have the right to contact the landlord yourself.
I would cut them off with a side cutter tool.
Used to snip wiring of all kinds.
ED
lenaitch likes this.
Old 03-25-2019, 05:49 AM   #5
Rewards Points: 7,826
Does the building have a maintenance person or handyman they use regularly? You could talk to them so next time they are in the area they just snip them.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 03-25-2019, 07:20 AM   #6
Rewards Points: 18
Not sure if you are allowed or not, but to cut them flush get a 9 inch flexible metal cutting blade on a sawzall. You can bend the blade as you are cutting such that it rides along the wood. That will give you a flush cut. I guess you could also use the blade from a hacksaw to do the same thing.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 03-25-2019, 07:39 AM   #7
Property Mgt/Maint
Rewards Points: 7,448
I agree with contacting the landlord first. That aside, I cut nails like this with a small right angle grinder with a thin cut off wheel. It trims flush and removes the burr too.
Bondo and dd57chevy like this.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 03-25-2019, 07:33 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,958
Ayuh,...... That's My "Go To" tool for such things,... ^^^^^
Bondo is online now   Reply With Quote
Old 03-25-2019, 11:01 PM   #9
JUSTA MEMBER
My variable speed DREMEL with the Cutoff Wheel, would cut very well also.
ED
Old 03-27-2019, 04:47 PM   #10
Contractor/Engineer
Rewards Points: 1,170
It's NOT YOUR PROPERTY.
If you touch it, you assume responsibility and associated liability.
Notify the landlord and owner in writing.
de-nagorg and dd57chevy like this.
Domo is offline   Reply With Quote
Old 03-31-2019, 07:50 PM   #11
Rewards Points: 256
Will do.
Thanks.
de-nagorg and Domo like this.
Old 04-01-2019, 02:24 PM   #12
Oso954's Avatar
Rewards Points: 726
They are still available. They are sold under various names, hoof nipper, shoe puller, end cutting nipper, farrier pliers, horse shoeing pliers, etc.
Here is an example from Amazon
https://www.amazon.com/Tough-Heavy-D...77C23387QY6H64
They are also great for pulling headless nails, once you develope a touch for it. When you first try it, you often clip the nail rather than pulling it.
kwikfishron likes this.
Oso954 is offline   Reply With Quote
Old 04-01-2019, 05:25 PM   #13
JUSTA MEMBER
A remedy for the accidental clipping of the nail.
Get a triangle file, use it on the center of the cutting heads, to make matching V notches. not too deep, just enough.
This creates a great puller of headless nails, as well as ones that have broken off or the head has came off.
ED
Old 04-10-2019, 06:34 PM   #14
Rewards Points: 906
Simplest approach is to take a hammer and bend the nails down and flatten them against the wall. It would take less than 5 minutes.
If you have a grinder or cut-of tool then a cutting wheel would cut the nails off flush.
Calson is offline   Reply With Quote
Old 08-04-2019, 07:33 AM   #15
Rewards Points: 12
You can take a cutoff wheel on a grinder and make quick work of it. Where Safety glasses and spray it with water after cutting each one off. this is to keep it cool and burning the wood and make the screw loose. Regards, BigD9105
BigD9105 is offline   Reply With Quote
Deck nails against ledger Piedmont Building & Construction 2 10-29-2014 03:37 PM
Rough Framing / Too Many Nails? powertoolguy Building & Construction 17 08-21-2014 11:12 PM
Nails? Nails? Nails?! gunns General DIY Discussions 18 03-06-2014 12:25 PM
Size/Type of Nails for Interior Framing? mfleming Building & Construction 2 09-16-2008 09:39 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
