Cutting 24 Gauge Hurrcane Panels - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree11Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By de-nagorg
  • 1 Post By mark sr
  • 2 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By ChuckF.
  • 1 Post By Nealtw
  • 2 Post By Porsche986S
Old 11-01-2019, 10:21 PM   #1
Rewards Points: 2,442
Cutting 24 gauge hurrcane panels
I have to cut about a dozen of these hurricane panels, 24 gauge galvanized steel.
The cut is difficult because of the heavier gauge, and cutting through the up-across-down-across pattern.
I tried a tin snip, no good.
My next move was going to be an angle grinder with a thin metal blade or a diamond blade, but I thought I would ask here first if anyone has a better idea.
miamicuse is offline   Reply With Quote
Old 11-01-2019, 10:30 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 130
Re: Cutting 24 gauge hurrcane panels
I'm going to subscribe as I'm not very knowledgeable in metal fabricating....
But how about a recip saw with a fine metal blade....???
de-nagorg likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 11-01-2019, 10:42 PM   #3
JUSTA MEMBER
Rewards Points: 4,790
A circular saw, with a Carborundum (carbide) blade.
Rig a straight edge from 2X and clamp it to the panel, hang the cutoff over the edge of a sawhorse, table, or other sturdy object.
Have a catcher ( 2nd person) to catch the cutoff, and follow the straight edge guide.
ED
Nealtw likes this.
de-nagorg is online now   Reply With Quote
Old 11-02-2019, 07:06 AM   #4
retired painter
Rewards Points: 552
While it can be done that way it would be hard to control the cut [straight line] .... or at least it would for me.
mark sr is offline   Reply With Quote
Old 11-02-2019, 08:51 AM   #5
Rewards Points: 50
Look into the use of a Pneumatic or Electric metal shears just make sure to get the correct blades. Also there are the sheet Metal nibblers that come both Pneumatic & elect.
ClarenceBauer is online now   Reply With Quote
Old 11-02-2019, 09:00 AM   #6
retired framer
Rewards Points: 24,200
de-nagorg and Marson like this.
Do not use flat bottom gables with scissor trusses.
Old 11-02-2019, 09:23 AM   #7
retired framer
Old 11-02-2019, 09:31 AM   #8
JUSTA MEMBER
Neal: Sold!
I change my recommendation, from the Carborundum to the DIABLO.
Quicker, leaves the cut cleaner, and not hot.
Still a straight edge would help to keep it straight.
ED
Old 11-02-2019, 09:35 AM   #9
retired framer
Originally Posted by de-nagorg View Post
Neal: Sold!
ED
Years ago I watched a show about the steel mills and they were cutting great big slabs with a saw you might see in a saw mill and have always wondered why we couldn't have that. If I was still cutting rebar I would want that blade.
Old 11-02-2019, 08:50 PM   #10
Rewards Points: 1,806
I watch a lot of the car shows on the Motortrend channel, and am always impressed by how good they are at cutting car metal with an angle grinder or die grinder with a very thin abrasive blade.
Nealtw likes this.
ChuckF. is offline   Reply With Quote
Old 11-02-2019, 09:18 PM   #11
retired framer
Now they are making saws that will catch the metal shards.
Old 11-03-2019, 08:54 AM   #12
Rewards Points: 642
When cutting the metal siding for various projects I had going on I used a circular saw with a standard plywood blade installed backwards . Cut fine but is noisy so wear ear protection .
de-nagorg and Nealtw like this.
Porsche986S is offline   Reply With Quote
Old 11-03-2019, 12:08 PM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,688
My next move was going to be an angle grinder with a thin metal cutting blade or
Ayuh,...... This, ^^^, is how I would go about it,.....
Old 11-07-2019, 10:00 PM   #14
tom_poconos's Avatar
Rewards Points: 346
I've been looking for a sheet metal cutter myself. Have you looked at nibblers? If you have a compressor you can pick up an air nibbler for about $30 at harborfreight. If you don't have a compressor like me, you can get a nibbler attachment for an impact driver for about $40 on amazon. Nibblers will cut up to 14 gauge, so it should make light work of 24 gauge. Electric nibblers are a rip.
Anyway, a nibbler might be the cheapest option but it might not be the straightest cut.
On the one ton temple bell
a moon-moth, folded into sleep
tom_poconos is online now   Reply With Quote
