Cut Hole In Metal By Hand? - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 11-17-2015, 04:01 PM   #1
Rewards Points: 1,428
Cut hole in metal by hand?
I need to drill a hole about 2" in a metal distribution panel to attach a conduit nipple to a sub panel...
but the hole saws are SO expensive!
I don't want to pay $15 just to drill one hole.
so rather than using a hole saw... can I use a hack saw or something like that to cut a round hole? If so, how could that be done?
Perhaps I could trace a circle with a compass and then drill a hole in the center with the largest bit I have, then cut slots from the center hole to the trace and work my way horizontally to cut the pieces off until I have a hole. Then clean with a file.
Any ideas?
poiihy is offline   Reply With Quote
Old 11-17-2015, 04:12 PM   #2
Rewards Points: 144
jigsaw
mako1 is offline   Reply With Quote
Old 11-17-2015, 04:15 PM   #3
Originally Posted by mako1 View Post
jigsaw
electric jigsaw?
We don't have an electric jigsaw
We have a reciprocating saw
Old 11-17-2015, 04:20 PM   #4
Rewards Points: 107
Proper way would be a punch . But they cost more than the hole saw.
jimn01 is offline   Reply With Quote
Old 11-17-2015, 04:32 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 640
Stop being stupid, spend the $15.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following 6 Users Say Thank You to rjniles For This Useful Post:
Bondo (11-17-2015), Crazyjake8493 (11-25-2015), Fix'n it (11-17-2015), joecaption (11-17-2015), MT Stringer (11-17-2015), oh'mike (11-17-2015)
Old 11-17-2015, 04:43 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,630
I agree that you are going to spend more time to reinvent the wheel.
Do you have a harbor freight around? They are better than just throw away.
$16 and you get a whole set.
http://www.harborfreight.com/34-in-5-in-carbon-steel-hole-saw-set-18-pc-68115.html
The Following User Says Thank You to Windows on Wash For This Useful Post:
poiihy (11-17-2015)
Old 11-17-2015, 05:13 PM   #7
Retired Moderator
Rewards Points: 7,174
I have a step drill for the electrical box holes--works well--but cost a lot more than $15.00
Old 11-17-2015, 05:14 PM   #8
There is a harbor frieght nearby and that looks like a good deal, thanks!
The Following User Says Thank You to poiihy For This Useful Post:
Windows on Wash (11-17-2015)
Old 11-17-2015, 05:16 PM   #9
I wanted a step drill bit but they are ridiculously expensive at HD and the biggest one is too small.
Ebay has good prices on bits but most of them are also too small.
Old 11-17-2015, 05:21 PM   #10
Rewards Points: 17,912
If you want to spend ten times more time and end up with jagged odd ball shaped hole with burrs that may or may not even fit the connector then do it by hand.
Step drill or hole saw is what I use.
Might take a whole 5 min. for perfectly round hole.
Old 11-17-2015, 05:51 PM   #11
MT Stringer's Avatar
Rewards Points: 254
A hole saw of that diameter will come in handy more than once.
Need to bore a hole in the back of a cabinet to pass cables through?
Or drill a hole in the top of a desk to pass cables through.
Or... always handy to have on hand.
MT Stringer is offline   Reply With Quote
Old 11-17-2015, 07:12 PM   #12
Retired Moderator
The step drills vary a lot in quality---I've tried the cheap ones and they do not last long--so I broke down and spent over $40.00 for a Milwaukee one
That was a couple years back---it is still as good as new.
Old 11-17-2015, 08:14 PM   #13
Rewards Points: 996
i have that set. pretty much garbage. but its 10+years old. so perhaps they are better now.
^this.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
MT Stringer (11-18-2015)
Old 11-19-2015, 07:44 AM   #14
Rewards Points: 1,356
with a 2" hole saw you drill must turn very slow (frist gear and not full throttle) or you will burn hole saw in few seconds
and for the kits at 16$ you will probably burn the hole saw after one hole, those are only good for wood most of the time
carmusic is offline   Reply With Quote
knock out hole on a metal box miamicuse Electrical 6 09-11-2014 11:37 PM
need help to find bit to drill 1" hole in metal humberguy Electrical 6 06-27-2014 12:22 PM
Hole in clapboard allowing birds to nest GarfE Pest Control 1 04-16-2012 11:14 AM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
