Curve In Sheet Metal - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 11-18-2015, 08:27 AM   #1
Rewards Points: 248
curve in sheet metal
I would like to try to make a metal lid for a BBQ grill.
Small flanges where it rested on the grill, and the sides would be approximately half-moons. I have a sheet-metal brake for making flashing, which could be used to make the flanges, but is there a clever way to shape a clean curve in metal if you don't have a roller-style brake?
diy888 is offline   Reply With Quote
Old 11-18-2015, 11:14 AM   #2
Low Slope Roofing
Rewards Points: 114
You can do it with a regular brake, just make very slight bends less then 5 Degs very close together, if you lower the clamping pressure of the brake there will not be solid lines, the angle of the bends, clamping pressure and amount of bends will dictate how tight the radius is.
1985gt is offline   Reply With Quote
The Following 4 Users Say Thank You to 1985gt For This Useful Post:
diy888 (11-20-2015), SeniorSitizen (11-18-2015), Windows on Wash (11-18-2015), Yodaman (11-20-2015)
Old 11-18-2015, 01:53 PM   #3
Rewards Points: 1,510
Touring a manufacturing facility and saw dozer blades that had been formed as you describe. A slight break line was visible and several degrees of heat was required.
I've formed light weight metal around pipe with success. But I will say one thing, it's easier to put just a little more radii in than take that too much radii I put in back out.
SeniorSitizen is offline   Reply With Quote
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
1985gt (11-18-2015), diy888 (11-20-2015)
Old 11-18-2015, 02:19 PM   #4
Low Slope Roofing
Rewards Points: 114
I bet it would be real hard on a piece of steel like that. DO you think harbor freight brake would handle it?
Old 11-20-2015, 05:45 AM   #5
Rewards Points: 248
I will give it a try.
Old 11-20-2015, 07:17 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 9,338
Go get a steel pipe, say at least 3" in dia and as long as the lid.
Then lay you sheet metal on a flat surface and then using a lot of pressure, roll the pipe back and forth on the sheet metal. It will start to curve.
They make machines to do this.
ddawg16 is online now   Reply With Quote
Old 11-20-2015, 08:51 AM   #7
Rewards Points: 17,912
Any metal fab, bigger HVAC shop should have one of these.
https://www.google.com/search?q=shee...hJVMPCjyy9M%3A
Might take a whole 5 min, to set up and run it through the rollers and you would have a nice smooth curve.
Old 11-20-2015, 02:29 PM   #8
Rewards Points: 248
With that kind of roller brake, is it possible to specify the radius? Could I ask them to "put a curve with a 7.25" radius on this piece"? Will they expect really thin stock, or could that kind of brake handle 10gauge rolled steel?
Old 11-20-2015, 04:09 PM   #9
Should not be an issue, the rollers can be adjusted.
Your biggest issue is going to keep it from rusting.
If it was mine I'd be getting it powder coated.
No way would I be trying to bend this on a brake made for coil stock.
Coil stock is just .019 thick, 10 gauge is about .140.
Old 11-23-2015, 08:04 AM   #10
Low Slope Roofing
Rewards Points: 114
We have one of those, no way you can roll 10 gauge though it. 20 Yes and it's hard to run by hand.
10 gauge would require a press brake or a hydro roller.
Old 11-23-2015, 05:21 PM   #11
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... I think I'd build a jig of 2x wood, set one side in, 'n fold the other side down into the opposite side,...
Rap it a few times with my leather mallet, 'n install the end panels,....
Brute force, 'n persuasion,...
The end panels will hold the shape,....
A little massage in the rest of it, just to give it a "Set",....
Old 11-23-2015, 06:03 PM   #12
Low Slope Roofing
Rewards Points: 114
10 gauge is over 1/8". That would require a lot of leather mallet persuasion.
HELP! New install Sheet metal and Furnace. HAVOC88 HVAC 6 01-20-2016 06:19 PM
Soldering sheet metal? miamicuse Plumbing 6 06-07-2014 10:36 AM
south florida sheet metal roof? Jacob84 Roofing/Siding 2 07-11-2011 03:17 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
