Corrugated Metal Use In Fencing - Metal Fabrication - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 01-01-2015, 05:21 PM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Originally Posted by onjtrainee View Post
Bondo~If I want to cut out corrugated metal, what's the least expensive tool I can buy/rent to do this?? Rather than large piece cut outs, I'm thinking eliptical patterns to let in light and air, but not much else.
Ayuh,.... Probably a sawsall,....
Old 01-01-2015, 05:26 PM   #17
Rewards Points: 706
You missed the part about eliptical cutouts..oh well, the plasma cutter is probably the way to go.
How do you rate a Ryobi multi tool?
onjtrainee is offline   Reply With Quote
Old 01-01-2015, 07:23 PM   #18
Bondo's Avatar
Ayuh,.... After ya mark 'em out, you'll see it's doable with a sawsall,....
With the corrugations, the cuts will be rougher than ya think, yet look perfectly fine from a distance,...
Much like hi-way sign paintin',...
Sometimes ya tear up the cut out piece, to make the remainin' part look like ya want it too,...
Drill a few holes to start a cut, 'n go from there,...
A cuttin' wheel on an angle grinder might be an option,...
Donno 'bout a multi-tool, never tried to cut sheet metal with one,...
Just yesterday, at the garage journal forums, there's a group gettin' together for a group buy on a smaller cheaper plasma cutter,...
google 'em up,... I don't wanna post a competin' link here,...
Old 01-02-2015, 09:52 AM   #19
Rewards Points: 706
I was only mentioning a multi tool because I thought it could be used as a grinder as well. Maybe I am wrong here. I have to go get something to cut through some nails in osb, and recut the OSB, was thinking the best tool would be a multi-tool. But if a grinder is a separate animal, better I know that now as I will need a grinding tool. Doesn't have to be anything fancy I'm guessing. Or should i just buy these tools separately, ya think? I'll need a sander as well...was just hopin a multi tool could take care of all that...including grinding holes in metal.
Old 01-07-2015, 02:17 AM   #20
Rewards Points: 324
Use a metal nibbler, something like this http://www.boschtools.com/Products/T...spx?catid=1073 to cut decorative holes. It is also good for any general cutting of the sheets, we use one when installing corrugated metal roofs--makes light work of roofs that have lots of hips & valleys. Just do the cutting over smooth concrete, or have a magnet handy, to pick up all the sharp little bits that come off the cutter.
There's a few corrugated metal fences in my neighbourhood, if I remember when passing them, I'll grab some pics.
mgp roofing is offline   Reply With Quote
The Following 2 Users Say Thank You to mgp roofing For This Useful Post:
mj12 (01-28-2015), onjtrainee (01-07-2015)
Old 01-28-2015, 07:14 AM   #21
Lord of Slums
Rewards Points: 1,974
mpg roofing- Where were you 20 years ago. 100 degree weather I am in a yellow rain coat cutting metal panels with a circular saw with a metal blade. The noise alone was enough to drive you mad.
mj12 is offline   Reply With Quote
Screws for Corrugated Metal Roofing PPBART Roofing/Siding 10 04-08-2014 06:28 PM
Corrugated Metal layout! Mel-Baum Building & Construction 56 04-27-2013 06:33 PM
Recommendations for roof type when reroof daluu Roofing/Siding 24 12-07-2012 02:23 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Corrugated metal walls OtisDriftwood Building & Construction 1 01-24-2011 02:30 PM
