Bending Hollow Metal Tubing - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree3Likes
  • 1 Post By Bondo
  • 1 Post By Johnny_inFL
  • 1 Post By Nealtw
Old 03-25-2019, 05:41 PM   #1
Rewards Points: 2
Bending hollow metal tubing
Brand new here, live in Jax Fl. I have a project where I need to bend 1 inch square alumium tubing.
I have seen a few tools out there but do not want to spend $$$$$ until I can confirm I need one. Any way to do this, anyone who has built something like this that is not too terribly hard, thoughts? Anyone in the Jax area that can help me bend this at a 45 degree angle for 10 rods?
It's a very specific short term need that I hope turns into a long term need.
Paul
roosterrusek is offline   Reply With Quote
Old 03-25-2019, 06:27 PM   #2
Big Dog
Drachenfire's Avatar
Rewards Points: 3,818
Re: Bending hollow metal tubing
See if there is a United Rentals nearby, they probably have the tool you need available for rent for about $15 a week.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 03-25-2019, 06:31 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,082
Ayuh,..... Use aluminum Conduit, 'n bend it with a Conduit bendin' tool,......
Other alloys won't behave the same, 'n will probably crush, or break,......
Oops,.... I missed the square part,.....
Yer probably gonna be outa luck, depending on the alloy,.....
joecaption likes this.
Old 03-25-2019, 06:36 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,658
Google "bending square aluminum tubing". It seems that you need metal fabricating tools. Perhaps you can rent them as mentioned.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 03-25-2019, 09:43 PM   #5
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,174
you say it is "for 10 rods" ~ you mean like fishing rods ??
check your local marinas - especially the pontoon boat places.
bent square tubing is common on the toons.
the machine that does it is like at the muffler shops with special
dies for square shapes. not something that you can rent from the
rental place. it needs to be anchored to the floor.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 03-26-2019, 12:34 AM   #6
retired framer
Rewards Points: 12,172
Johnny_inFL likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Two Questions: halex 90 degree connectors; grounding/wire in metal boxes tooltime88 Electrical 3 05-19-2018 12:56 PM
Asphalt roofing Transition to Metal Roof BigJim Roofing/Siding 7 04-13-2018 08:10 AM
metal sheathing DiegoJames Electrical 2 07-01-2013 06:59 AM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
