Basement Handrailing - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree1Likes
  • 1 Post By rrmccabe
Old 10-24-2018, 06:04 PM   #1
Rewards Points: 322
Basement handrailing
When we built the house I never put handrail to the basement. We had some water issues in basement at the end of June from heavy rains (10") which broke the egress window and flooded basement.
So since I had to re-do the woodwork and drywall I figured I might as well continue the handrail to the basement. As we get older I appreciate the handrail more all the time.
So just got rolling. Need to find matching cable and hardware so I can get the holes drilled for those and get it powder-coated. Everything is DIY in the garage using a TIG.
jaketrades likes this.
rrmccabe is offline   Reply With Quote
Old 10-24-2018, 06:28 PM   #2
Rewards Points: 17,912
Re: Basement handrailing
If your in the US (no location in your profile so we have to guess) what you have there now may not meet modern codes.
There needs to be a grip able handrail.
https://inspectapedia.com/Stairs/Rai...tions.php#Reqd
Old 10-24-2018, 06:45 PM   #3
Rewards Points: 322
Thanks for the info. Yes, I am in the US. I am going to make it match the rest of the house regardless of code. It was inspected in 2010 (right or wrong) and passed. But will do a little digging on that just out of curiosity.
Old 10-24-2018, 07:37 PM   #4
retired framer
Rewards Points: 20,348
I have seen that and I too have wondered about code, they used to get excited if kids could climb over. But hay it looks good.
Nealtw is offline   Reply With Quote
Old 10-25-2018, 04:26 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Great work,..... Looks absolutely Fantastic,.....
Bondo is online now   Reply With Quote
My Basement Journey tojo78 General DIY Discussions 8 06-23-2017 07:53 PM
Crawlspace Encapsulation / Basement Vents and Registers Anomaly0 HVAC 0 06-13-2016 01:41 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
