Ayuh, My Lazy Man's Wood Splitter,... - Metal Fabrication - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 02-24-2016, 12:51 PM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Well,..... I have to report severe disappointment,......
While it does split rounds such as in the inventor's vid, small 12"/ 18" dia. straight grained rounds,....
It don't even come close with the monster hard maple rounds, even the shorter stuff, much less a knot,....
It does make a 'ell of a grapple, but on a backhoe, motion is limited,...
I'm chalkin' it up as a failure,...
Probably gonna put the 2' diggin' bucket back on,...
The Following 4 Users Say Thank You to Bondo For This Useful Post:
47_47 (02-24-2016), BigJim (02-24-2016), de-nagorg (02-24-2016), oh'mike (02-24-2016)
Old 02-24-2016, 05:05 PM   #17
JUSTA MEMBER
Rewards Points: 4,038
Maybe if you devise a thinner blade on it, that 1 inch looks a bit wide to me, or taper the wedge to a finer thickness.
Maybe you could fashion a thinner blade that attaches to your digger bucket, and just use it as a powered wedge to split hardwoods.
ED
de-nagorg is online now   Reply With Quote
Old 02-25-2016, 08:59 AM   #18
47_47's Avatar
Rewards Points: 320
The problem is the bucket is meant for digging and probably only pushes 4 ton. To split bigger wood, you'd need to increase your curl cylinder to get 15 + ton. At that force, you'd probably take out your bucket pins or wreck your dipper arm.
47_47 is offline   Reply With Quote
Old 02-25-2016, 05:13 PM   #19
Bondo's Avatar
Ayuh,.... I ain't completely given up, 'n pulled it off yet,.....
1st thought was/ is to carve the 1, 3/4" blade to a more tapered edge,....
I figure I can cut that back, like I cut it out the 1st time, with the bluetip wrench,...
Even then it ain't gonna be enough,....
Don't need it for small wood, need it for the 3', 4', 5' rounds, 12" to 20" long,....
With Knots,.... Lotsa Knots,....
So far, it's half-azzed handy at knockin' the frozen pile Loose, 'n movin' the rounds over too, or onto the splitter,....
The 4 tooth, 2', digger bucket is missin' a tooth, so I do use one, or two teeth to break up rounds I didn't quite cut all the way though/ evenly,....
Also good for splittin' apart tightly grown crotches,....
Splittin' factor is limited to the weight of the tractor,... 'bout 8 ton,....
As for the cylinder, it's 'bout 3, 1/2",.....
I'm thinkin' a 5" might be enough,...
Donno's I'm gonna do that, got enough goin' on now,....
Still gotta check the pressure of the by-pass valve,....
Might turn it up abit, if the pumps got it available,....
The Following User Says Thank You to Bondo For This Useful Post:
de-nagorg (02-25-2016)
Old 02-26-2016, 07:42 AM   #20
47_47's Avatar
Rewards Points: 320
Glad to hear you're going to check it first. Some guys are just turn it up...
The Following User Says Thank You to 47_47 For This Useful Post:
de-nagorg (02-26-2016)
Permanent Wood Foundation: Basment Questions!!! topdiggy2 Building & Construction 17 02-19-2016 09:10 PM
Question regarding bare wood behind top of gutter voodoochile Roofing/Siding 16 09-03-2015 03:00 PM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
