Ayuh, My Lazy Man's Wood Splitter,... - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 02-09-2016, 08:17 AM   #1
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh, My lazy man's wood splitter,...
I guess I oughta start a thread in here 'bout my home made lazy man's wood splitter,....
Not that I'm all that lazy, but I did break a rib a year ago Christmas day,...
I burn chuck wood in my home made outdoor wood boiler to heat this house, 'n for dhwater,...
Since I finished the build 6 or 7 years ago, I've been barterin' with a local tree service,....
I fix Frank's equipment, 'n answer his questions by phone, so he can fix whatever's bein' a problem,....
In exchange, he brings me all the wood I can burn,....
The draw-back is it's all residential trees, of whatever species it happens to be,...
(although, I won't take willow, 'n I bytch when he shows up with Poplar)
It's also sometimes fulla nails, house shoes, wire, 'n God knows what else,....
Last Christmas, I was wrestlin' 5' rounds of hard Maple, had one almost stood on edge to roll to the splitter, when my fingers slipped off, 'n I went azz over tea kettle, fallin' onto another huge round strilin' my back, 'n breakin' a rib, round back, mid-back high,....
6 weeks on the couch, tryin' not to cough,.... really Sucked,...
Well,.... Durin' those 6 weeks I cruised the web lookin' for a better design, for a hoe mounted splitter,....
Most all of 'em, use an added hyd. circuit to power the splitter,...
That's a pain to rig on my 555E Ford hoe, as well as expensive valvin', 'n lines,....
I'd already started huntin' the iron to build one, when I stumbled across this one,...
It simply replaces the hoe's bucket, 'n uses the hoe's original hydraulics,...
I called the guy, 'n it's 2 Grand to buy one,...
Bein' the Handy type, 'n havin' access to mountains of steel, I'm buildin' my own version,...
I cut some of the plates, 'n got it tacked together,...
Hope to be splittin' wood with it by this comin' weekend, but time will tell,....
I'll up-date this thread, as it comes together,....
This is where it's at so far,....
Headin' 'cross town here soon to drill a couple mountin' plates,....
I'm movin' the top of the knife out away from the dipper to make the blade angle alittle Better,...
The Following 2 Users Say Thank You to Bondo For This Useful Post:
47_47 (02-09-2016), r0ckstarr (02-13-2016)
Old 02-09-2016, 08:24 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,614
That thing looks like it is going to be a beast.
Keep the thread up to date with pictures. Looking forward to it.
Old 02-09-2016, 10:10 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,650
I love it, I've busted my share of wood and actually enjoyed it when it was clear without knots. I really fouled my back up bustin wood, but that was years ago.
I love seeing new ways to do a tough job, I will be watching your build. Speaking of huge chunks of steel, what would make a good anvil, right now I am using my 12 pound sledge hammer but it is just too light for an anvil.
Looking at the title of your thread, even with a spliter, there is still hard work working with fire wood, anyway you go it is going to still be back breaking work, just not as much with your machine.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-09-2016, 11:29 AM   #4
Bondo's Avatar
Ayuh,.... I've got 2,.... One I made outa an "H" beam piece, 'n the other is an actual Anvil, though pretty beat up, 'n broken,....
I ain't got a picture handy of the actual anvil mounted on a big block of wood,....
This picture is an old one of my boiler, long before it was completed,...
You can see the H beam, that I welded stiffeners into, 'n mounted it on an ole beer keg,....
It Works, but ain't at all a Nice anvil,....
It's just to LOUD when ya beat on it, 'n I've learned that an anvil works best, when mounted to a huge block of wood,.....
The wood isolates it some what, 'n cuts the ringin', 'n bounce,...
Yet is still Solid when ya wack it,...
I ain't used the one I made much,...
If yer interested, I can pull the H beam off the beer keg, 'n send it to ya,....
You pay the freight, 'n can mount it on a block of wood to get the table height ya need,....
This is a poor picture of it, but all I've got at the moment,...
Old 02-09-2016, 12:57 PM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Nice build..I have the same 37 ton splitter in your first picture, from northern tools...I cut my own firewood upstate , so no nails and manageable pieces..
WhatRnsdownhill is offline   Reply With Quote
Old 02-09-2016, 02:59 PM   #6
Bondo's Avatar
Ayuh,.... The only real Problem I've got with it is the Hinge,....
tightened it many times, redesigned the bolt up system, then just Welded the whole mess to the tube,....
They redesigned the whole machine, 'n that hinge on the current models,....
Ain't been able to get a good look at it, to see If I wanta go that way, or build my own version,...
Also bought, but ain't mounted yet, an electric start,...
Coldest blooded Honda I've ever seen,....
Bein' loaded at idle don't help, so I try to remember to leave it extended enough to open the throttle, when I shut it down,...
For the New splitter,...
Just got back from the Fab Shop,... Gotta go out, 'n clean up the pieces, 'n clamp 'em up to see how it's gonna fit,...
Old 02-09-2016, 03:31 PM   #7
the only problem I had on the northern splitter was in the hydraulic fittings by the hand control, the cheap o rings split, put new ones in and no more problems there, and the thin bolts that hold the handle on the return valve wore through, just drilled one size bigger and used 2 hardened bolts...never had an issue starting it, but it doesnt sit out in the ice cold, I keep it in the shop till needed..
Old 02-12-2016, 03:35 PM   #8
Bondo's Avatar
Well,.... It's been colder than a witch's tit up here the last few days,....
Yesterday, single digits after a night of well below Zer0 °,....
That heavy iron, is C O L D to the hands, gloves or not, mittens have helped,...
Got it torn apart, welded on the longer blade mount to the dipper yesterday,...
Today, snowin' to beat the band, can hardly see the hiway at times,...
Got it fabbed up again, 'n clamped into place,...
Still needs some hammer tunin', then tack it up, 'n weld on it for awhile,...
Maybe tomorrow,...
Old 02-12-2016, 03:56 PM   #9
looking good, if it works out,I might have to borrow that design for my backhoe...I have the thumb mount on the rear stick of the hoe, so half of the splitter design is almost there...
Old 02-12-2016, 04:08 PM   #10
Bondo's Avatar
Ayuh,.... That's a Ford 555E with an extend-a-hoe,....
I welded the top mount for the knife, 'bout an inch below the main dipper, on the extension,....
Moved the top hole, 'bout 4" further out from the dipper,...
On the thumb side, I think I'm gonna rotate the 4x6 box tube 'bout 90°, 'n open up the gullet abit,....
There's easily 24" 'tween the thumb, 'n knife, especially with the angle of the knife,...
Hopefully, I'll be chewin' through that mountain of hard maple rounds in the backyard soon,...
Gettin' down on wood up by the boiler,....
Might have to fire up the ole gas splitter,...
Old 02-12-2016, 04:09 PM   #11
Concrete & Masonry
Rewards Points: 336
If you already have the backhoe, and they have enough "curl" power, that looks like a good, warm way to split.
This is what I use to split firewood. I hook one of the skidloaders to it for reliable power. If I have a lot of big stuff and some help, I'll use the other skidloader to bring the big pieces up to the table, and they just roll them off of the forks.
Other wise, I've borrowed one of these once from a frinedly competitor of mine:
http://www.woodsplitterdirect.com/30...er-attachment/
jomama45 is offline   Reply With Quote
Old 02-12-2016, 04:13 PM   #12
LOL..I have a triple nickle too.......with an extra long stick...
Old 02-12-2016, 04:17 PM   #13
Bondo's Avatar
Ayuh,.... Originally, that's the direction I was headed,....
A splitter like that, mounted to the end of the hoe,...
Just the valvin', 'n plumbin' for another hyd. circuit woulda been Hundreds of Bucks,.....
This one I found on y-tube, 'n the steel is left-over from done jobs,...
The bucket curl cylinder is 4, 1/2",....
That'd be 30 tons on my gas splitter, as it's 37 ton with the 5" cylinder,...
I know that years ago, when We'd 1st bought this machine, I hooked into a chunk of concrete, at Full reach, at Full extension, 'n when I curled the diggin' bucket, it lifted the entire machine on the outriggers,...
The whole tractor, 'n front bucket were Floatin',...
Donno,.... We'll see,... Soon hopefully,....
Old 02-12-2016, 05:54 PM   #14
Retired Moderator
Rewards Points: 7,174
I'll be watching---that is a dandy looking rig.
Old 02-12-2016, 09:50 PM   #15
JUSTA MEMBER
Rewards Points: 4,026
That's interesting.
Nothing like YANKEE ingenuity. I like it.
Jim asked about Iron for a good anvil.
I have a 2 foot section or RAILROAD track, that I got at a junk yard, that works very well as an anvil, You will need to mount it on a stand to get it to a
comfortable height for yourself, but you can pound on it and pound on it and not hurt it.
Apologies extended for temporarily pirating your topic!
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
BigJim (02-13-2016)
Permanent Wood Foundation: Basment Questions!!! topdiggy2 Building & Construction 17 02-19-2016 09:10 PM
Question regarding bare wood behind top of gutter voodoochile Roofing/Siding 16 09-03-2015 03:00 PM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
