Adding Holes To A Burn Barrel - How To ? - Metal Fabrication - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Like Tree7Likes
Old 11-12-2018, 01:31 PM   #16
Rewards Points: 2,568
Re: adding holes to a burn barrel - how to ?
Originally Posted by de-nagorg View Post
A wood burning stove, in the shop will take care of any scraps, and heat your workspace in winter also.
May be an option, besides wasting the fuel.
ED
That's where my wood scraps go and the - to be burned - stack is a lot larger than my completed stack of projects.
de-nagorg likes this.
Old 11-12-2018, 01:50 PM   #17
JUSTA MEMBER
Rewards Points: 324
Maybe you are too much of a perfectionist, and reject decent projects
with " CHARACTER" as flaws.
I do too often myself.
ED
SeniorSitizen likes this.
de-nagorg is online now   Reply With Quote
Old 01-01-2019, 06:34 PM   #18
Rewards Points: 666
Thought I would post an update . Weather here was good after Christmas so I loaded up the 357 magnum and fired 21 rounds into the can Gave me 42 decent sized vent holes and was fun so a win/win ! So now I have to cut the top off and cut a square in the bottom and weld in some screen/grate material and I can fire her up ........ pun intended
Porsche986S is offline   Reply With Quote
Old 01-01-2019, 10:58 PM   #19
JUSTA MEMBER
Rewards Points: 324
21 rounds of 357, Remind me to never make you angry, that much anger built up is not good for you.
Glad that you got it relieved before the new year, I hope that you are calmer now.
ED
Old 01-02-2019, 07:54 AM   #20
Originally Posted by Bud9051 View Post
A hole in the bottom might risk hot ashes falling out and being carried with the wind.
Bud
With both top and bottom removed and set on bricks the draft is so strong I've never found that to be a problem.
Old 01-02-2019, 08:52 AM   #21
Rewards Points: 666
ED
Seinfeld reference: serenity now serenity now I'm a pretty mellow roll with the punches kind of guy but I will admit shooting that barrel felt good ! I rotated the barrel to get somewhat of an even hole pattern . Even though I was using 38 special FMJ ammo I was quite impressed with the performance . So stay off my lawn !
Raising toilet flange (tiled floor); bought Set-rite; screw holes don't line up lazzlazz Plumbing 12 09-12-2017 08:59 PM
Need help installing a grab bars on already established holes Spend Drywall & Plaster 9 01-21-2015 05:07 PM
Questions about holes in drywall, uneven ceilings, and refinishing after popcorn Joe Link Drywall & Plaster 1 08-21-2014 08:27 AM
What Made These Holes? Koldhammer Pest Control 3 05-24-2014 03:22 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
