95 Ford Ranger - Metal Fabrication - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Metal Fabrication
Old 02-09-2016, 03:13 PM   #1
95 Ford ranger
I had to cut the drivers side frame rail from behind the cab back because of rust and I have already purchased another frame that was cut from the same kind of truck behind the cab.My question is can any body give me some advice on putting it back together?
fivestring is offline   Reply With Quote
Old 02-09-2016, 04:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,746
Ayuh,.... Ain't done a little truck, done lotsa class 8 trucks,...
Oughta be 'bout the same,.....
Pull back or remove all the wirin', 'n plumbin' in the area,....
Clean, 'n prep the frame ends for weldin', position 'em into place, 'n tack 'em up,...
Keep recheckin' yer measurements to keep things aligned, 'n keep tackin' it together,....
When ya got a full-pen weld, grind it clean, 'n flush,....
Fab up some fisch plates to span the area, inside, 'n out,...
Clamp 'em in-place, 'n start tackin' 'em in,....
Keep tackin', 'n cleanin', 'n checkin' til the plates are welded all 'round, Except the vary ends at the points,....
'n I always leave a tiny gap at the bottom to drain any water,...
How well equipped are ya,..??
What welder,..??
Old 02-09-2016, 06:42 PM   #3
Rewards Points: 254
What bondo said, but we went one farther stretching frames we drill holes on each side of the splice and used grade 8 bolts as back up if the welds cracked. But the straight trucks we made were for a fertilizer coop. And were always over loaded driving through fields too
cjm94 is offline   Reply With Quote
Old 02-09-2016, 10:25 PM   #4
Not at y'all iv got a welder coming to help but if he don't show by this weekend I'm going to buy me a dang welder and jump in head first.slowly I assure you...Iol thanks for the advise .
Old 02-10-2016, 08:17 AM   #5
Rewards Points: 1,456
i hope this is for off-road only, i wouldn't trust a rusted 95 pickup with welded frame parts on the road...
carmusic is offline   Reply With Quote
Old 02-10-2016, 09:41 AM   #6
Well if knows what he is doing I don't see why not.and I'm going to put bolts in it to.
Unique Ford Ranger Exhaust?? Giles Automotive Repairs 3 07-31-2011 03:37 AM
1998 Ford Ranger Electrical Problem - Turn Signals, 4Wheel Drive Yotta Automotive Repairs 2 04-06-2011 07:59 PM
93 Ford Ranger A/C problem robcourtis Automotive Repairs 1 06-14-2010 10:20 PM
1997 ford ranger running hot gclark0024 Automotive Repairs 5 06-19-2009 05:47 PM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 01:24 PM
