Is There A Way To Adjust TV Monitor Same Resolution As Laptop? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 11-17-2019, 09:21 PM   #1
VAer's Avatar
Rewards Points: 1,626
Is there a way to adjust TV monitor same resolution as laptop?
Laptop resolution: 1920x1280.
TV: Ultra HD LED TV 3840 x 2160
I used to connect the laptop to projector in basement, but I don't really go to basement a lot, now I decide to bring laptop to first floor and connect it to TV. At least, I am planning to use the laptop for the TV monitor for majority of time.
I am trying to display laptop on TV monitor, but not whole screen is shown on TV, there is a little edge outside TV monitor.
I tried to adjust laptop resolution, it also looks strange that no whole screen is utilized (black screen on the sides).
Is there a way to let it fully displayed on both monitors (laptop monitor & TV monitor). Basically, I mean stretch to fit. At least stretch to fit TV monitor, no matter how I adjusted laptop resolution, either something is out of TV monitor or some black screen left on TV monitor.
Thanks.
VAer is offline   Reply With Quote
Old 11-17-2019, 09:45 PM   #2
VAer's Avatar
Re: Is there a way to adjust TV monitor same resolution as laptop?
I think I have another TV monitor 1920X1080, which is also not 1920x1280
Old 11-17-2019, 10:33 PM   #3
retired framer
Rewards Points: 510
go to settings and display you should be able to set it there.
Do not use flat bottom gables with scissor trusses.
Old 11-17-2019, 11:06 PM   #4
VAer's Avatar
TV setting or laptop setting, I could not find a way to change TV setting. It seems that 1920x1280 is some kind of "unusual" resolution.
Is there a way to adjust TV monitor same resolution as laptop?-img_20191117_223722.jpg   Is there a way to adjust TV monitor same resolution as laptop?-img_20191117_223802.jpg
Old 11-18-2019, 12:01 AM   #5
retired framer
Rewards Points: 510
I use a TV for second monitor, set it in the computer settings. you can set the resolution and to be a duplicate or side by side with the first monitor.
Old 11-18-2019, 12:55 AM   #6
Hammered Thumb
Rewards Points: 308
Sounds to me like you need to change the "Picture Mode" of the TV to "Normal," rather than "Wide," "Stretched," "Zoom," or "Cinema."
3onthetree is offline   Reply With Quote
Old 11-18-2019, 07:16 AM   #7
VAer's Avatar
Thanks. It is AspectRatio setting under Picture Mode, there is PC Mode. I was always looking into OPTION, I was assuming majority of setting is inside OPTION.
Is there a way to adjust TV monitor same resolution as laptop?-img_20191118_070945.jpg
Old Yesterday, 05:35 PM   #8
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 563
You could always use a Chromecast.
Deja-vue is online now   Reply With Quote
