Need To Know For Cable Splitters - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Like Tree3Likes
  • 1 Post By ktkelly
  • 1 Post By raylo32
  • 1 Post By lug-nuts
Old 07-09-2019, 03:01 PM   #1
Rewards Points: 314
Need to know for cable splitters
Wife and I just moved.
New place has cable ran to all the rooms, but no splitter at the point the cable comes into the house.
One in, 6 out, to various rooms.
Looking around amazon are amplifiers, bi-directional splitters, and voltage blocking terminators...
I have comcast and want to have the ability to hook a TV up in the 6 rooms in the house with a cable jack. What do I need for a good picture?
Fisher1871 is offline   Reply With Quote
Old 07-09-2019, 05:01 PM   #2
Rewards Points: 1,434
Re: Need to know for cable splitters
Umm, how do they magically split into 6 wires?
Comcast should do the work for you, setting you up either under a move package or as a new customer.
Depending on Comcast's agreement with your city/county, they may require a box for every TV.
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
ktownskier is online now   Reply With Quote
The Following User Says Thank You to ktownskier For This Useful Post:
Fisher1871 (07-10-2019)
Old 07-09-2019, 06:21 PM   #3
adam
Rewards Points: 140
You probably need what's known as a 'drop amplifier' similar to this: https://www.amazon.com/Splitter-Sign...%2C129&sr=8-28
You should verify this with Comcast or perhaps they can suggest one.
adamz is offline   Reply With Quote
The Following User Says Thank You to adamz For This Useful Post:
Old 07-09-2019, 06:39 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,938
I had numerous TV's on one Comcast system...(but before HD).... and put on an off the shelf $40 amplifier...and it worked great.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 07-10-2019, 11:43 AM   #5
Hammered Thumb
Rewards Points: 1,772
I thought that is the only way for Comcast, Direct or Dish. You can only split it after the box, so any other tv is watching whatever is on the main box. That's how they get you, $7.99 for every box monthly. Unless you stream service to each tv.
3onthetree is offline   Reply With Quote
Old 07-10-2019, 12:08 PM   #6
Mystriss's Avatar
Rewards Points: 3,100
This is the one I bought for my setup, has the best reviews - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My cable company has a "whole home" package for TiVo which uses a "MOAC" that lets us put it wherever we want and buy our own tivo boxes and such (or we can watch online or mobile too) If you have something like this splitter where your service line comes into the house then you've probably got a similar situation
That said some companies do require you to have a box to "unscramble the signal" at each TV - ours used to be like that maybe 10 years ago.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 07-10-2019, 12:19 PM   #7
I have had Comcast, Directv and Dish. And they all have required a satellite box for every TV. However, I have negotiated to either getting all of the receivers free or at a reduced rate. Especially when renewal time comes up. Just ask for a retention specialist.
Another option is to have a smart device like a TV or or Blu-Ray player. You won't get anything from cable or satellite but you can sign up for Amazon Prime, Netflix, Hulu and others. And now you can even get DishAnywhere and similar apps so that you can watch it on your portable devices and even your smart devices.
Old 07-17-2019, 10:11 PM   #8
Rewards Points: 1,754
Cut the cord. Mostly anyway.
Off Air antenna with a Tivo OTA and Tivo Mini's then add a Netflix account for streaming.
Dave Sal likes this.
ktkelly is offline   Reply With Quote
Old 07-19-2019, 09:17 AM   #9
raylo32's Avatar
Rewards Points: 808
If you have one cable coming in to the house and 6 cable outlets you already have a splitter somewhere. You shouldn't need any sort of amp... but you will need a cable box for each TV. It can get very $$.
My house has all the cables home run to one place so I have one TV on cable and the rest on my OTA antenna. I can mix and match with splitters out there. Having one cable box was just a small $ over a bare internet connection so it made sense but I will have to revisit this when my 2 years are up. The antenna TVs are also connected to the Internet so can stream plenty of stuff that way. We also have FiOS available here so we can play them against Comcast when necessary. But what a racket it all is. I had cut the cord totally until last year and can always go back that way if Comcast and VZ don't keep prices down.
Fisher1871 likes this.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-29-2019, 03:17 PM   #10
Rewards Points: 228
You need a Cable TV HDTV Amplifier Splitter check the link
https://www.amazon.com/PCT-Bi-Direct...s%2C199&sr=8-8
lug-nuts is offline   Reply With Quote
The Following User Says Thank You to lug-nuts For This Useful Post:
Fisher1871 (07-29-2019)
