Low Home Speaker System Volume - Home Theater - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-15-2015, 09:28 AM   #16
Rewards Points: 94
Originally Posted by Nobr8ks View Post
No, saw your post on AVS...
whatever you say, don't really have any personal info on either of these sights
Stop taking your equipment apart before you actually break something.
too late, ive already burned down the house destroyed everything except for this Elan Audio System thankfully
Last night in the "wood panel room" I verified power at 20 VAC (whether or not that's what required I don't know), then turned all the knobs to the center position and plugged in my 3.5mm/rca adapter to my phone and still wasn't able to get any music out of them?
Maybe I can find a receiver I can borrow just to test out the system, do you know what the screw switch is inbetween the 2 RCA inputs? Its a smooth switch and doesn't have any tactile positions.
Any ideas on testing that amp? Im thinking just to connect another stereo and speakers that I have into the amp
jeckel7234 is offline   Reply With Quote
Old 10-15-2015, 12:25 PM   #17
Rewards Points: 150
That center adjuster, my guess is master volume control. Thus, adjust to center as well.
confirm voltage on terminals, 5 (15v-) & 7 (15v+) Are you using a meter?
If there's power, with a small screwdriver pull wire (tape each wire off) on terminals 2, 3, and 4 (Mute)
plug in phone and test...
Nobr8ks is offline   Reply With Quote
Old 10-15-2015, 12:50 PM   #18
Rewards Points: 150
Those 2 RCA's, "Red Room" (Right & Left inputs) are for pre-out only... Don't connect main R & L from a receiver, you'll muck things up.
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 08:42 PM
Home Security System RHulsmeyer Electrical 0 04-13-2012 01:46 PM
Reverse Osmosis system for home -- Costco "Watts" model dynamo Plumbing 2 12-28-2011 09:45 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
