Issue With Tv Image - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-06-2019, 04:25 PM   #1
Rewards Points: 291
Issue with tv image
Hello
The Sharp Aquos TV in my gazebo worked fine until 3 or 4 weeks ago. Now, the inage looks like in the attached images.
Might someone have a clue as to what it could be? Is it fixable and worth fixing?
Issue with tv image-img_20191006_152941_1570397073276.jpg   Issue with tv image-img_20191006_152758_1570397088251.jpg
NABRIL is offline   Reply With Quote
Old 10-07-2019, 07:29 AM   #2
Rewards Points: 7,127
Re: Issue with tv image
HD Tvs are rarely worth the expense of fixing unless you have the skill and knowledge to DIY.
Sorry I don't have a clue, something in the display part of the board is my WAG.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-07-2019, 10:03 AM   #3
Rewards Points: 291
thanks Colby..I figured that, and the repair is probably more expensive than a new TV. In my case, the TV was a gift from a friend that didn't have use for it. When he bought it, it was the top of the line TV, and it looked amazing until 3 weeks ago.
Old 10-07-2019, 10:57 AM   #4
You might try a hard reboot, unplug it for a few minutes.
Colbyt
Old 10-09-2019, 11:19 AM   #5
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 515
I'd open it up and look for some loose Cables, and check for blown Capacitors.
Most likely, it is one of the Tcon boards. There should be two, one left and one on the right.
I fixed many of those. But with 55 inch 4K TV's now dropping into the $300 Range, probably not worth fixing it.
Deja-vue is online now   Reply With Quote
