HDMI To Antenna Adapter - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Like Tree1Likes
Old 06-15-2020, 11:26 AM   #1
Rewards Points: 50
HDMI to antenna adapter
Iíve been searching online for an adapter since I just upgraded my DirecTV receiver to the Genie box. Unfortunately, there is no antenna( RG 6 type) output which I need so i can split the feed out to watch TV in the basement. ( Too cheap to pay for an extra receiver). I saw one on Radio Shack online, but it seems to be always out of stock. Anyone know where else i can get one?
99 wirenuts is offline   Reply With Quote
Old 06-15-2020, 01:05 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,972
Re: HDMI to antenna adapter
The adapter you need will be box not just a cable. You need a modulator to convert the HDMI signal to a an RF type output.
Mystriss likes this.
Old 06-15-2020, 02:00 PM   #3
Rewards Points: 8,685
I never heard of one and could not find HDMI to coax.
I did find an HDMI splitter if the basement TV has HDMI. There are 2 options on this page: https://www.monoprice.com/search/ind...HDMI++splitter
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 06-15-2020, 02:40 PM   #4
Rewards Points: 50
I was thinking about splitting the HDMI Feed, but wasnít sure how long you can run Hdmi cables, or how long you can buy hdmi cable. I would probably need about 40í.
Old 06-15-2020, 02:43 PM   #5
Like many video, audio and data cables, HDMI cords can suffer from signal degradation at longer lengths—50 feet is generally considered the maximum reliable length. And it's rare to see an HDMI cable longer than 25 feet in a store.Jun 29, 2011
How To Extend Your HDMI Cables - DIY Tech
www.popularmechanics.com › home › how-to-extend-your-hdmi-cab.
Everything is cheaper at Monoprice and shipping is reasonable.
Colbyt
Old 06-15-2020, 06:24 PM   #6
adam
Rewards Points: 246
If you have Internet in the basement, you might consider using a Chromecast. Assuming you're DirecTV susbscription supports it.
If it works, you won't need to scream this upstairs "hey change the genie receiver to my fav. channel" :-)
https://www.att.com/support/article/att-tv/KM1226927
adamz is offline   Reply With Quote
Old 06-15-2020, 06:29 PM   #7
Mystriss's Avatar
Rewards Points: 7,350
Joed is correct, you need a modulator to convert HDMI to RF (RG6) / RF to HDMI.
https://www.amazon.com/s?k=RF+Modula...ref=nb_sb_noss
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 06-15-2020, 06:31 PM   #8
adam
Rewards Points: 246
Is there an analog output or other outputs on the back of the Genie?
Old 06-15-2020, 06:49 PM   #9
Mystriss's Avatar
^^ Ah yeah, good catch @adamz -- If your box happens to have RCA's you can use multiple runs of RG6 to carry to the signal, usually need at least 3 though (right, left audio & one video) You can often run RG6 video, then a Toslink or speaker wire for right/left audio.
Putting an RCA connector on the end of an RG6 is surprisingly easy too, I just did a ton of them myself. I explained the process here: https://www.diychatroom.com/f49/week...2/#post6128077 (Putting on an RCA tip is exactly the same process, you're just using an RCA connector instead of an F-Style connector )
Old 06-16-2020, 05:22 AM   #10
Rewards Points: 50
I will look again when i get home, but I think I only have an S-video, USB port and a single RCA audio jack in addition to the HDMI.
Old 06-16-2020, 07:20 AM   #11
That's an old TV but you can buy hdmi-svideo converters https://www.google.com/search?client...-video+adapter
With the current price of TVs it might be cheaper to just buy a new one.
Colbyt
Old 06-16-2020, 06:23 PM   #12
Rewards Points: 50
Thatís not the TV, its the DirecTV Genie receiver outputs
Old 06-18-2020, 03:03 PM   #13
adam
Rewards Points: 246
If the Genie has S-video out and RCA out audio, you can use a device like the one below from Home Depot. You can then use your coax cable to feed ch. 3 or 4 to the 2nd TV set.
https://www.homedepot.com/p/Zenith-R...MOD1/310551736
Amazon has them too, just search for "rf modulator with s video" in Amazon's search bar.
Old 06-18-2020, 04:36 PM   #14
Super Moderator
joed's Avatar
Many old VCRs had antenna out. If you have one with an HDMI input and antenna out you could use that.
Old 06-19-2020, 07:47 AM   #15
I'm asking, not stating a known fact. Are you sure? I thought those were only feed thru splitters with no path to feed another input to the antenna out.
Colbyt
