Deoxit - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Like Tree5Likes
  • 1 Post By Deja-vue
  • 1 Post By joed
  • 1 Post By diyorpay
  • 1 Post By GrayHair
Old 09-12-2020, 10:04 PM   #1
Dave Sal's Avatar
Rewards Points: 32
Deoxit
Hey guys,
I have a Denon AVR3300 5.1 AV receiver from about 2000. Works well, except after about two hours of use, it starts to emit an annoying whistling sound which I'm pretty sure is coming from the internal fan. I've removed the top cover and planned on replacing the fan but it looks like I'd have to remove a bit more stuff than I am comfortable with.
I was thinking of disconnecting one of the power leads to this fan and then add an aftermarket fan on the rear of the receiver exhaust port.
Today my son mentioned Deoxit and said that it can clean, protect, and lubricate electrical components. This sounds like something that might work in my receiver to quiet the fan.
Just wondering if anyone has any experience with this stuff for AV equipment. Thanks
Dave Sal is offline   Reply With Quote
Old 09-15-2020, 12:22 PM   #2
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 725
Re: Deoxit
@DaveS al, I must admit, you keep things around for a long Time.
Good for you.
But, and I know you expect a post like this from me, it is time to let go.
That Receiver hasn't even got an HDMI port, was built in 1999 or so, probably cost over a grand back then.
Not to mention it doesn't have all the High-end Sound Formats like DTS-HD, Dolby Atmos and the like. And the Power (105W x 5) isn't up to today's Receivers. No Bluetooth, Pandora, or XM and the like.
If you are a Costco Member, check out this Beast here:
Dave Sal likes this.
Deja-vue is offline   Reply With Quote
Old 09-15-2020, 12:39 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 142
Re: Deoxit
The part that is squeaking is likely not open to being sprayed. The fans I have lubed have all had a metal sticker over the bearing that needed to be pulled off to oil. A couple of drops of 3in1 usually does it for at least a short time.
Also if it lubes I would not want to spray it around inside the receiver.
Old 09-16-2020, 10:31 AM   #4
Rewards Points: 30
Re: Deoxit
Can of compressed air used on computers?
Could be dust buildup?
diyorpay is offline   Reply With Quote
Old 09-16-2020, 06:08 PM   #5
Deja-vue's Avatar
Rewards Points: 725
Re: Deoxit
Folks, I hate to tell you but:
Fans do wear out. Period. I replace them on computers all the time.
So none of your Ideas will work. Temporary, maybe.
Permanently, not.
Old 09-18-2020, 04:31 PM   #6
GrayHair's Avatar
Rewards Points: 34
Re: Deoxit
Deoxit (formerly Cramolin) is a great contact cleaner, restorer and lubricant (note that lubricant appears last in that list!). Many years ago I used Cramolin Red to clean and Cramolin Blue to preserve relay contacts in old fire alarm panels.
Also works great on RF connectors on boats. It was recommended by an engineer at a recording studio. He used it on noisy controls on the mixing boards.
I would never recommend it as a straight lubricant and as was pointed out, fans wear out.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is online now   Reply With Quote
