Can I Use Very Large Magnet Speaker With Small Radio - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Like Tree6Likes
  • 4 Post By Johnny_inFL
  • 1 Post By SPS-1
  • 1 Post By lenaitch
Old 11-23-2018, 08:32 PM   #1
Rewards Points: 133
can I use very large magnet speaker with small radio
I have a small battery clock radio speaker that I would like to replace with a very efficient large magnet speaker of the same impedance. Would the small battery powered radio be able to drive it at all? Thanks
Hossenfeffer is offline   Reply With Quote
Old 11-23-2018, 08:55 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 688
Re: can I use very large magnet speaker with small radio
Without knowing the data of both the radio output and the speaker, I would guess not likely. The internal speaker will be matched to the tiny power output of the radio (watts) and likely won't be sufficient to move the magnet of the large speaker.
I'm actually surprised that a clock radio would even have an external speaker jack.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 11-24-2018, 12:56 AM   #3
Rewards Points: 1,300
I don't see why the voice coil wouldn't move. are you talking about replacing a 1" 8 ohm speaker with an 8" 8 ohm speaker?
u3b3rg33k is offline   Reply With Quote
Old 11-24-2018, 06:52 AM   #4
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,268
LOL LOL this question brings back some very fond memories. . . . .
when I was on a Navy destroyer back in the '60s, I wanted to
hear music in my office . . . so I ran a wire from my little battery transistor
AM radio speaker to the ship's 1MC speaker in my office . . . . it worked GREAT !!
BUT - it also bled into ALL the speakers throughout the ship,
including the Captain's speaker . . . ohhhhhh not good. the ship's
electrician traced it back to my office (and me) and I got all kinds of reprimands.
so, yes . . . it "can" be done. it just depends on your expectations of the results.
try it and see . . . nothing ventured, nothing gained.
Dave Sal, Mike Milam, Domo and 1 others like this.
Johnny_inFL is offline   Reply With Quote
Old 11-24-2018, 08:02 AM   #5
Rewards Points: 8,986
Originally Posted by lenaitch View Post
.... tiny power output of the radio (watts) and likely won't be sufficient to move the magnet of the large speaker.
The magnet is stationary. Its the voice coil that moves.
I would think it will work fine. But don't expect it to be any louder just because its going to a bigger speaker --- you need more power to make it louder.
lenaitch likes this.
SPS-1 is online now   Reply With Quote
Old 11-24-2018, 06:06 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 688
Yup, of course you are correct. If the power output of the radio is very small, it might not be enough to generate strong enough fields in the large magnet unless it is a good quality, high sensitivity speaker. It's the reverse of a mis-match the other way; a low power rated speaker connected to a high power source and gets 'over stimulated'.
As mentioned, it might work, just not with the results expected. Nothing will get damaged. Nothing ventured, nothing gained. At least the OP won't get hauled before the mast like Johnny did.
Dave Sal likes this.
Sic Itur ad Astra
Old 11-25-2018, 06:09 PM   #7
Rewards Points: 133
Thanks everyone. So if I understand correctly I will not damage the little amplifier in the clock (It is actually a little Seiko mantle clock with a tiny battery powered unit that chimes....loudly..yet I want to experiment. This unit does not run on AC at all, just one AA battery)
I usually wire up little amplifiers in my HO model trains decoders to little transformers, then run them into inputs into a stereo amplifier. The result is phenomenal...but decoders actually runs on 13 v and 3 amps. This mantle clock will be nothing like that.
I would have tried it already except that I did not want to damage the clock.
I would match the impedance going from a two inch speaker up to a high end 4 inch full range speaker I have pulled from a stereo.
Old 11-25-2018, 06:17 PM   #8
Rewards Points: 1,314
Originally Posted by Hossenfeffer View Post
..... I would like to replace with a very efficient large magnet speaker of the same impedance.
As was mentioned, there is nothing wrong in trying.
Just pointing out that the larger magnet isn't necessarily more efficient. What would be more efficient would be to take a smaller speaker sized appropriate for the radio, and using a neodymium magnet. The more concentrated magnetic field will get more driver movement from a smaller power source. That's why headphones use them....it was actually the breakthrough that permitted super small but powerful headphones.
BrownEyedGuy is offline   Reply With Quote
Old 11-25-2018, 10:15 PM   #9
Rewards Points: 133
Thanks again. Now, to be clear.... I won't toast the little circuitry by attaching this large speaker? It really is a high end speaker, believe me. Yes, I know about neodymium. I have a box of them I used for undertrack train uncouplers on the model train layout. There is a great website that sells all kinds.
Old 11-25-2018, 10:50 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 688
delete
Sic Itur ad Astra
Old 11-25-2018, 11:45 PM   #11
high end does not mean a good db/W rating. just hook it up and tell us what happens already.
Old 11-26-2018, 12:12 PM   #12
Scumbag Lawyer
Location: Northern Virginia, which I'm told is different from "real" Virginia
Rewards Points: 194
As long as the new speaker has the same impedance as the old speaker, the magic smoke should remain safely contained in the circuitry.
PatentPending is offline   Reply With Quote
Old 11-29-2018, 05:56 PM   #13
Rewards Points: 133
Thanks. I do a lot of speaker work with the train decoders.
Sorry to be tedious about possible damage. The clock is worth over $250 and is brand new.
Seeking advice for repairing small tear in bathroom linoleum floor lonlonmilklover Flooring 3 01-10-2013 03:08 PM
Best Small Work Radio Chris Sweeney General DIY Discussions 4 11-10-2012 09:38 AM
Where to find bulk small wire? Red Squirrel Electrical 13 06-14-2012 10:38 PM
Rabbeting large pieces on small table saw Klawman Carpentry 3 12-05-2009 08:59 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 11:17 PM
