Wifi Network Crashing - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 04-25-2018, 02:38 PM   #1
Rewards Points: 310
Setup
Cable Modem: Motorola Arris Surfboard
Switch: Tough Switch PoE Pro, TS-8-PRO
Access Points: UniFi Enterprise WiFi System
Router: Cisco of some sort (will have to get the model later).
I have 4 access points installed, distributed as evenly as possible around the property.
The guys that live in the house tell me that the system stops working multiple times per day. They reset the router and then it will work fine for a bit. It's never not worked when I'm present.
Sometimes there are upwards of 60+ devices (PCs, TVs, Laptops, gaming consoles) connected.
I used a wifi analyzer app and it's spread across channels 1, 6, and 11. 2.5GHz.
I'm not sure how to go about diagnosing the problem.
Any thoughts?
Fisher1871 is offline   Reply With Quote
Old 04-25-2018, 06:09 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,344
Re: Wifi Network Crashing
Not sure either with all that periphery connected. I had a similar problem in that the system would crash. Turned out to be the modem, which the provider replaced the first time free of charge. Then greed set in and they replaced it a second time a year later and wanted to charge me $10 a month. Heck modems sell for $30 online, so I opted out of that and sent it back to them.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Fisher1871 (04-26-2018)
Old 04-25-2018, 06:34 PM   #3
ZZZZZ's Avatar
Rewards Points: 1,628
Originally Posted by Fisher1871 View Post
Setup
Any thoughts?
60 devices is A LOT for one router to route, especially if they're pulling a lot of bandwidth such as online gaming.
I'd check with Cisco support and see what they say. You may need to upgrade.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
The Following User Says Thank You to ZZZZZ For This Useful Post:
Old 04-25-2018, 07:21 PM   #4
Guapo
Rewards Points: 11,950
It's simple math. It's crashing because the default DHCP range is probably only 50 IP addresses & they have more than 60 devices. A Class C subnet can handle up to 253 devices.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
Old 04-25-2018, 09:09 PM   #5
Rewards Points: 178
If you have a UniFi controller running the event log should show you any issues with the APís. Iím guessing your router is running out of memory or is overheating.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 04-26-2018, 10:21 AM   #6
Rewards Points: 310
Great suggestions!
I'm trying to get in touch with guy that set up original network to see if the router/modem was configured in some way with the switch/APs.
I want to swap out both to test.
I believe the DHCP was set to 50-250 addresses. Can one do that without a class C subnet? Maybe he only partially set it up correctly to handle more than 50 devices.
Old 04-26-2018, 11:04 AM   #7
Rewards Points: 310
I think I may start with upgrading to a netgear cm1000 and an edge router x sfp.
Remove the tough switch entirely.
The edge router will support the 4 APs I have plus a security camera system. I have the DHCP set to support from 50 - 250.
Old 04-26-2018, 03:05 PM   #8
Guapo
The basic home router uses a Class C subnet by default. That will handle 253 devices. The DHCP default range is usually 50 addresses, wired or wireless. All wireless devices should be able to receive an IP address within 150' range without using any other hardware such as repeaters, extenders, switches, etc... If you still have trouble, list every device that you are using & how they are being used. The more info that you provide, the easier it will be to solve the problems.
Old 04-26-2018, 06:40 PM   #9
Rewards Points: 770
interesting
Wesman is offline   Reply With Quote
Old 04-26-2018, 06:41 PM   #10
Rewards Points: 178
You should consider a switch and/or router from the UniFi line since you already have the APs. Essentially the same ad EdgeRouter but with different badging. The UniFi controller integrates all of the devices.
Dan
Fisher1871 (04-27-2018)
Old 04-27-2018, 09:35 AM   #11
Rewards Points: 310
Good idea.
I ordered the Ubiquiti router. The APs are 2ghz (or 2.x whatever). I am considering upgrading those to 5ghz and if I do so, I'll use Ubiquiti. Keep all the hardward the same.
Carrier Infinity Wifi Thermostat not working Hawkeye481 New Member Introductions 0 09-14-2017 08:53 AM
Honeywell 8000 wifi problem Patrick Eubanks HVAC 9 11-16-2013 01:20 PM
1958 Ranch Home, Full of Character - First Home, First Major Project Thadius856 Project Showcase 519 05-11-2013 09:43 PM
Converting cable Internet to WiFi?? polarzak PC Repairs & Upgrades 7 06-25-2012 08:49 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
