DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Networking (https://www.diychatroom.com/f11/)
-   -   Wifi Network Crashing (https://www.diychatroom.com/f11/wifi-network-crashing-619593/)
Fisher1871 04-25-2018 02:38 PM
Setup
Cable Modem: Motorola Arris Surfboard
Switch: Tough Switch PoE Pro, TS-8-PRO
Access Points: UniFi Enterprise WiFi System
Router: Cisco of some sort (will have to get the model later).
I have 4 access points installed, distributed as evenly as possible around the property.
The guys that live in the house tell me that the system stops working multiple times per day. They reset the router and then it will work fine for a bit. It's never not worked when I'm present.
Sometimes there are upwards of 60+ devices (PCs, TVs, Laptops, gaming consoles) connected.
I used a wifi analyzer app and it's spread across channels 1, 6, and 11. 2.5GHz.
I'm not sure how to go about diagnosing the problem.
Any thoughts?
chandler48 04-25-2018 06:09 PM
Re: Wifi Network Crashing
Not sure either with all that periphery connected. I had a similar problem in that the system would crash. Turned out to be the modem, which the provider replaced the first time free of charge. Then greed set in and they replaced it a second time a year later and wanted to charge me $10 a month. Heck modems sell for $30 online, so I opted out of that and sent it back to them.
ZZZZZ 04-25-2018 06:34 PM
Originally Posted by Fisher1871 (Post 5425849)
Setup
Any thoughts?
60 devices is A LOT for one router to route, especially if they're pulling a lot of bandwidth such as online gaming.
I'd check with Cisco support and see what they say. You may need to upgrade.
Guap0_ 04-25-2018 07:21 PM
It's simple math. It's crashing because the default DHCP range is probably only 50 IP addresses & they have more than 60 devices. A Class C subnet can handle up to 253 devices.
djlandkpl 04-25-2018 09:09 PM
If you have a UniFi controller running the event log should show you any issues with the APís. Iím guessing your router is running out of memory or is overheating.
Fisher1871 04-26-2018 10:21 AM
Great suggestions!
I'm trying to get in touch with guy that set up original network to see if the router/modem was configured in some way with the switch/APs.
I want to swap out both to test.
I believe the DHCP was set to 50-250 addresses. Can one do that without a class C subnet? Maybe he only partially set it up correctly to handle more than 50 devices.
Fisher1871 04-26-2018 11:04 AM
I think I may start with upgrading to a netgear cm1000 and an edge router x sfp.
Remove the tough switch entirely.
The edge router will support the 4 APs I have plus a security camera system. I have the DHCP set to support from 50 - 250.
Guap0_ 04-26-2018 03:05 PM
The basic home router uses a Class C subnet by default. That will handle 253 devices. The DHCP default range is usually 50 addresses, wired or wireless. All wireless devices should be able to receive an IP address within 150' range without using any other hardware such as repeaters, extenders, switches, etc... If you still have trouble, list every device that you are using & how they are being used. The more info that you provide, the easier it will be to solve the problems.
Wesman 04-26-2018 06:40 PM
interesting
djlandkpl 04-26-2018 06:41 PM
You should consider a switch and/or router from the UniFi line since you already have the APs. Essentially the same ad EdgeRouter but with different badging. The UniFi controller integrates all of the devices.
Fisher1871 04-27-2018 09:35 AM
Good idea.
I ordered the Ubiquiti router. The APs are 2ghz (or 2.x whatever). I am considering upgrading those to 5ghz and if I do so, I'll use Ubiquiti. Keep all the hardward the same.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
