Tp-link Tl-wr740n - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 06-25-2020, 11:23 AM   #1
Super Moderator
joed's Avatar
Rewards Points: 32,020
tp-link tl-wr740n
I am experiencing a very strange issue my router.
From my PC I see the router and login to it. I can see and change all the settings. Yet I have no internet connection.
Here comes the strange part.
If I call my ISP they can see the router from their end.
So somewhere inside the router the input and the output are not connecting.
For now I plugged my ISP feed direct into my PC. Everything works fine except I do not have WIFI for my cameras.
I'm thinking I should just go and buy a new router.
Old 06-25-2020, 12:27 PM   #2
I would try a hard reset before buying a new router
McGillicuddy is offline   Reply With Quote
Old 06-25-2020, 02:50 PM   #3
Super Moderator
joed's Avatar
Re: tp-link tl-wr740n
I forgot to mention I tried that. Used a paper clip to push the master reset button.
Old 06-25-2020, 03:50 PM   #4
Rewards Points: 1,118
It's a 2.4 GHz. No 5 GHz. It's pretty old. It may not offer updates.
5 GHz will give you access to newer bandwidth (less radio crowded). There are even newer bandwidths.
Direct wired to a modem or a router with ports plugged into a current generation modem is very fast. If fast wi-fi is important, upgrade. The modem and router work together. Upgrading both should be considered. Fast wi-fi is dependent on the pairing of these two and the speeds your IP provides.
diyorpay is offline   Reply With Quote
Old 06-25-2020, 06:21 PM   #5
Rewards Points: 286
Have you tried rebooting both the modem and router? Unplug both and restart the modem first.
Dan
djlandkpl is online now   Reply With Quote
Old 06-25-2020, 10:23 PM   #6
Super Moderator
joed's Avatar
The ISP hardware is an antenna on the roof. It apparently has a small router built in. that is why I am able to use the internet without the tp-link. I will check my local computer shop for a new unit soon.
