New Cat5e - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Like Tree1Likes
  • 1 Post By rjniles
Old 05-12-2016, 01:24 PM   #1
Rewards Points: 224
New cat5e
I am going to replace the original 1958 telephone wiring in my house with cat5e which should be fairly easy to do since most of the wiring is accessible from the basement and it's only one floor . The question is once the wires are hanging in the basement what is the best way to connect all the wiring ? I took out the old lightening protector when the phone company installed a new NID on the outside several years ago. The ends of the wiring in the basement which is about 4 or 5 home runs are just twisted together as of now and are not connected to the NID because they were disconnected from the current service provider which I now have from a coaxial cable.
daveblt is offline   Reply With Quote
Old 05-12-2016, 03:20 PM   #2
47_47's Avatar
Rewards Points: 320
Re: New cat5e
Use a 66 or a 110 punch down block.
47_47 is offline   Reply With Quote
Old 05-12-2016, 03:25 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 17,378
Re: New cat5e
What ^he^ said....
ddawg16 is online now   Reply With Quote
Old 05-12-2016, 03:50 PM   #4
Rewards Points: 224
Re: New cat5e
What is the difference between the punchdown block and a patch panel block ? Also can I use the NID to run the wiring to instead ?
Old 05-12-2016, 04:13 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 162
Re: New cat5e
What are you using the Cat5 for?
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-12-2016, 04:20 PM   #6
Rewards Points: 224
Re: New cat5e
For phone .Actually my modem provides form the phone with the coaxial cable and it plugs into a jack which supplies the rest of the jacks in the house.
Old 05-12-2016, 05:04 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 162
Re: New cat5e
You are wasting your time and money. no need for CAT 5 for phone service.
GrayHair likes this.
Old 05-12-2016, 06:29 PM   #8
JOATMON
ddawg16's Avatar
Re: New cat5e
I strongly disagree.....as will most phone experts.
Cat 5/E/6 is outstanding for phone line usage.
1. Excellent signal characteristics
2. Inexpensive (cheap)
3. Multi-line (up to 4 phones)
4. Robust
5. You can use existing crimpers to crimp an RJ-11 plug on it.
Why buy just phone line cable when that spare chunk of Ethernet cable will work as well if not better.
Old 05-12-2016, 07:28 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 162
Re: New cat5e
4. Robust
Why replace existing inside wire (most likely CAT3 ) if all you want is phone service? If this were a new install I would agree with you as CAT 5/6 can be used for data.
I would not call myself a phone expert but I did work in a local wire line Telco for 33 years.
Old 05-12-2016, 10:33 PM   #10
Rewards Points: 224
Re: New cat5e
This is not even cat3 . It is the existing 2 pair from that precedes cat3 from 1958 .
Old 05-12-2016, 11:04 PM   #11
JOATMON
ddawg16's Avatar
Re: New cat5e
So you will know what AML and CM8 is?
Old 05-13-2016, 01:38 AM   #12
Rewards Points: 6,652
Re: New cat5e
If there is no static or noise on the old Telco wire, it will continue to work for a long time.
Pulling Cat-5e only works if you can get it to where the current jacks are. When you pull it, pull two runs to each outlet. One for Ethernet and the other for phone.
I only ran six wires when I redid my network. Two jacks have two each and two have one. That is because I have a switch at those jacks that I have more than two pieces of gear that needs to be hard wired.
Our phones are Cellphones, no need for landline or Digital VoIP.
Old 05-13-2016, 01:40 AM   #13
Re: New cat5e
Actually that is what is being ran these days for phones in homes. Offices all get Cat-6 runs for every jack. Different colored jackets for different uses. Makes it easier to ID.
Old 05-13-2016, 01:41 AM   #14
Re: New cat5e
It is just standard Bell Wire that is a heavier gauge than anything used these days. It will last for a lot longer. All that you need is only one pair for phone. Tip & Ring.
Old 12-24-2017, 05:57 PM   #15
Rewards Points: 219
Re: New cat5e
I have a Comcast modem and it has a input for a phone line
bote110 is offline   Reply With Quote
Wiring Cat5e - totally stumped eyc908 Electrical 38 02-09-2015 12:07 AM
Running CAT5e To Detached Garage propman07 Electrical 17 09-27-2014 01:05 PM
What type of cat5e cable type fastener? Ranger31 Electrical 8 06-29-2011 10:01 AM
Help/Suggestions Running Cat5e Acroos Room To New Panel darveaux Electrical 6 02-28-2011 03:12 AM
Phone and Ethernet Using CAT5e haffey Electrical 2 08-25-2008 11:54 PM
